Old 11-11-2015, 01:58 PM   #11 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by TimV View Post
1-alternator
You need to be carefull. The alternator cant put out a lot of power.
It's also the most inefficient power source, being powered by the combustion engine.
If it's running,use it to propel the car.
When using heaters, insulate the engine compartment or you'll be heating the environment.
Old 11-11-2015, 03:50 PM   #12 (permalink)
SUVcruiser - '07 Ssangyong Kyron 2.0 XDI
90 day: 42.55 mpg (US)
SUVcruiser year 2017 - '07 Ssangyong Kyron 2.0XDI
Hybridcruiser 2023 - '13 Volvo V60 D6 AWD
90 day: 123.84 mpg (US)
Using the alternator as a power source does help warming up times. It put a load on the engine so it heats up faster. This is only benifetical if you do long trips. Otherwise it is running all the time and wont have time to pay it back.
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011+ 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
Old 11-11-2015, 09:45 PM   #13 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
I don't think using the alternator Is a good idea either. You are right that it puts a load on the engine and that is probably the biggest reason not to use it. If it is loading the engine then it is burning more fuel. The gas you are trying to save by warming the engine faster is being burnt up from the extra load on the engine. You may even get worse mileage, don't know. As for long trips, preheating the engine is only helping for the first 5-10 minutes of driving anyway, just until it gets to operating temp. Besides, wasting fuel to save fuel never pays in my mind.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
Old 11-26-2015, 03:38 AM   #14 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
My 91 dodge d250 diesel worms faster with the defroster on. Noticeably faster ..
1 small load is not sufficient to add fuel at idle slows thw motor insted
2 heat from the condenser helps to worm the coolent in the radator
3 the added heat helps the thermal fans viscous fluid to sleng out and disengage (slow almost stops drawing in freezing air through the coolant)
4 ac condenser coil is in front of my intercooler. Heat is transferred to my intake air charge via the intercooler
The important things to remember
1turn fan speed down to 1 / low till wormed up
2 turn to plain heat to disengage the compressor
As for transmission heating dodge released a tsb saying not ro use overdrive@ temps below 5°f because the atf will freeze in the air to liquid transmission cooler and burn up the transmission. So a 12 volt heater would se good in my application. It would alow me to run overdrive(higher gear trumps additional altanator1load )
Add thermal isolator tape , sleeve, split loom, on all coolent hoses to reduce heat loss (ever try to hold on to a heater hose @ operating temperature? Wellits operating temperature!! ) my 2cents well spent
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
