Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 04-26-2011, 05:19 PM   #1 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
EnviroTabs - I pop a pill and...
I have no idea what this is but can I put it into the pasture ?
Greenfoot Global ::
How Does It Work?
EnviroTabs® is an organometallic metal conditioner that acts as a burn rate modifier which catalyzes fuel. This action allows more of the fuel to burn in the power stroke of the engine and therefore less fuel burns in the exhaust stroke.
EnviroTabs® simultaneously improves fuel economy, increases power and reduces emissions by creating a micro-thin coating in the combustion chamber of your engine which allows fuel to burn quicker.
EnviroTabs® burns off carbon deposits and catalytically causes a chemical reaction to happen at a lower temperature. The fuel particles begin to combust at temperatures as low as 200º C, as opposed to 600° C. This chemical reaction allows the impurities and the hard carbon deposits to completely burn off.
EnviroTabs® changes the surface heat absorption characteristics of metal. Note: The greatest loss in efficiency in an automobile engine is the loss of heat. Heat is energy released by the mixture of fuel and air; which produces a heat spike, which creates expansion used to power the vehicle. The cylinder walls and head are water cooled, and the pistons are oil cooled. The thin coating inhibits the transfer of radiant heat. This means higher combustion temperature, greater expansion and more power with reduced emissions. By increasing the burn in the combustion chamber (rather than as after-burn) performance can be increased while reducing fuel consumption and emissions. Heat recovery is the single best method that can reduce harmful emissions, increase fuel economy, improve engine performance and extend oil and engine life.
Does it work with all types of fuels?
Yes - EnviroTabs® works at the chemical level of the combustion process and therefore works exactly the same way regardless of the type of fuel in which it is used. EnviroTabs® are formulated for use with all types of gas and diesel fuel grades, which includes E-85, two-cycle mixed fuels, and blends of diesel (winter, summer and bio). EnviroTabs® works in any combustion engine-car, truck, motorcycle, generator- you name it!
Just put EnviroTabs® in your fuel tank before filling up. The tablet will completely dissolve in minutes, often times before you are done filling-up. Once dissolved it passes through the fuel line and past the fuel filter using the fuel as a carrier. EnviroTabs® does not modify or alter the fuel in any way.
Now I may be reading too little into this but I'm thinking 'bollocks'*
*(apologies to sensitive readers or family viewers...)
No longer here. Bye, and good luck to all.
Old 04-26-2011, 05:59 PM   #2 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Start of ignition @ 200°C sounds like premature detonation to me.
Lifetime fuel consumption :
Old 04-26-2011, 08:47 PM   #3 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...are they related to Magnetic Hare Pellets?
Old 04-26-2011, 09:06 PM   #4 (permalink)
JRMichler's Avatar
Nameless - '06 Canyon
90 day: 33.19 mpg (US)
And, gosh golly gee whiz, they have an SRI report that says that fuel with their pellets in it is exactly the same as fuel without their pellets in it. Sounds like they are selling GENUINE 100% placebo.
But, to be fair, genuine 100% placebo has been proven effective in the past.
Old 04-27-2011, 08:34 AM   #5 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
so i can now buy a tablet to change the metallurgical charecteristics of my engine block? SWEET!!!
Old 04-28-2011, 01:17 PM   #6 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
Complete BS "The fuel particles begin to combust at temperatures as low as 200º C, as opposed to 600° C"
I do not know where they got those numbers but autoignition temp of Gasoline is ~280º C unless they are trying to claim that it will lower the burn point of carbon monoxide from 609º C to the range of gas
If the needed burn temp is dropped significantly it in creases the chance of knock caused by autoignition (the way diesel works) this will lead to reduced ignition timing, increase in cylinder pressure that could blow out gaskets.
I move at the speed of awesome.
Old 04-28-2011, 01:28 PM   #7 (permalink)
Half Pint - '09 Rio SX
90 day: 44.81 mpg (US)
I'm pretty sure the only burn that is going to happen is to the person who got "burned" by purchasing their magic pill.
Old 04-28-2011, 04:45 PM   #8 (permalink)
5 Gears of Fury
War_Wagon's Avatar
Lumpy - '00 Insight
90 day: 49.98 mpg (US)
Grendel - '00 Firefly
90 day: 39.17 mpg (US)
Salty - '91 Tercel DX
90 day: 35.27 mpg (US)
The only pill that ever helped my F.E. was Ritalin, it lets me concentrate a lot harder on my tach and shift points lol
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
Old 04-28-2011, 05:15 PM   #9 (permalink)
Send a message via MSN to markweatherill
No, I reckon it's cold fusion.
Old 04-29-2011, 04:46 AM   #10 (permalink)
"EnviroTabs® does not modify or alter the fuel in any way."
Truer words were never spoken! Or printed. Or typed. Or whatever . . .
