Old 10-19-2010, 10:48 PM   #1 (permalink)
Got soul?
Soulster's Avatar
Soulster - '010 Soul Plus
90 day: 35.36 mpg (US)
100k POS - '01 Neon
Eoc
I want to install a fuel injector kill switch on my Kia Soul so i can EOC, however i am quite clueless when it comes to electrical things, what schematics do i need?
Old 10-20-2010, 12:15 AM   #2 (permalink)
eco....something or other
wood hauler - '91 F-250
90 day: 22.06 mpg (US)
3800 Sunfire - '02 Sunfire
Try a Haynes or Chilton manual. They usually have most of the things you need.
Mine show all the wiring and even the wire colors.
1991 F-250:
4.9L, Mazda 5 speed, 3.55 10.25" rear.
Old 10-20-2010, 04:34 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Where are you planning to install? Inside the car at the ECU (in which case you'd need an ECU pinout diagram) or at the injectors under the hood (in which case you just need to figure out where they care and bypass them individually with a switch).
Old 10-20-2010, 05:56 AM   #4 (permalink)
Got soul?
Soulster's Avatar
100k POS - '01 Neon
well all the wires run to behind the glove box, so i was hoping to intercept it there and put in a normally closed relay switch and then run a micro switch or something like that out to near the shifter knob.
Old 10-20-2010, 10:49 AM   #5 (permalink)
Got soul?
Soulster's Avatar
100k POS - '01 Neon
I went looking for some diagrams and this is what I found:
ECM
1. ECM (Engine Control Module)
2. Manifold Absolute Pressure Sensor (MAPS)
3. Intake Air Temperature Sensor (IATS)
4. Engine Coolant Temperature Sensor (ECTS)
5. Throttle Position Sensor (TPS)
6. Crankshaft Position Sensor (CKPS)
7. Camshaft Position Sensor (CMPS)
8. Knock Sensor (KS)
9. Heated Oxygen Sensor (HO2S) [Bank 1/Sensor 1]
10. Heated Oxygen Sensor (HO2S) [Bank 1/Sensor 2]
11. CVVT Oil Temperature Sensor (OTS)
12. A/C Pressure Transducer (APT)
13. Fuel Tank Pressure Sensor (FTPS)
14. Fuel Level Sensor (FLS)
15. Injector
16. Idle Speed Control Actuator (ISCA)
17. Purge Control Solenoid Valve (PCSV)
18. CVVT Oil Control Valve (OCV)
19. Canister Close Valve (CCV)
20. Ignition Coil
21. Main Relay
22. Fuel Pump Relay
23. Data Link Connector (DLC)
24. Multi-Purpose Check Connector
Do any of these tell me what I need to interrupt? Location of what to snip?
I am wanting to do something similar to what Niner did: Adding injector cutoff to a Scion xA
Thanks!
Old 10-20-2010, 10:59 AM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I would suggest try interrupting lead 2 on the CKPS or the CMPS signal (K80 or K82) and see if it dies cleanly with one or both of those opened (i.e. with a normally closed microswitch on the shifter like you suggested). My crankshaft sensor was easier to locate and tap into on the engine block end fyi.
Old 10-20-2010, 04:53 PM   #7 (permalink)
Niner_xA - '05 xA
90 day: 35.82 mpg (US)
Horse Hauler - '95 F-250 XLT
90 day: 13.47 mpg (US)
Butterkup - '02 Miata
Hm, on Toyota vehicles, all those "to main relay" lines go back to a single line that goes to the keyswitch. On yours, I'm guessing they don't enter the engine cabin again, but go over to your engine bay relay box. If you can track them back (and they go to a single wire) that would be a good place to interrupt all 4 at once. Otherwise, you could also put 4 relays in on the 4 lines that go to the injectors from the ECU (pins 25-28) and kill them all at once.
Old 10-20-2010, 04:54 PM   #8 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Thats what I did with mine and I ended up with a check engine light (no other adverse effects though).
Old 10-20-2010, 05:08 PM   #9 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
Niner, we think alike. That was what I was going to have my brother look into. If he can find a spot where thee join that is where it will be interrupted. I am not sure about the four relays, but it might work.
Old 10-21-2010, 01:47 PM   #10 (permalink)
Steve's Suzuki - '00 Swift GA
90 day: 51.99 mpg (US)
On my 2000 Suzuki Swift, I tapped into the underside of the FI fuse under the hood. Standard Tab terminals fit right on. I used a relay to switch the power wire coming out of the fuse. I mounted a button right on my shift knob. I dont have a working camera or i would get some pics.
Quick Test: P&G with EOC vs w/o EOC shows 24% gain Daox Hypermiling / EcoDriver's Ed 16 10-08-2010 12:16 AM
Battery options for EOC - long distance brucepick EcoModding Central 19 09-04-2010 09:38 AM
Perfecting Going EOC After Dark Jammer Hypermiling / EcoDriver's Ed 20 09-30-2009 08:27 PM
EOC and bad mpg... 97Cavalier Hypermiling / EcoDriver's Ed 10 05-05-2009 08:23 AM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 01:18 PM
