Old 04-25-2008, 04:14 PM   #1 (permalink)
Focus - '05 Focus ZX3 SE
90 day: 30.86 mpg (US)
EOC - concerns
While doing some very low-speed (luckily) testing of EOC (engine-off-coast) in a parking lot, at one point during a turn, I was coasting, and had apparently turned the key to 'off' rather than 'accessory', and the steering wheel locked. I had enough time to slow down and unlock the steering wheel, but it was a scary adrenaline-filled second when the wheel wouldn't turn where I wanted it.
Anybody else ever run into this and/or is there a way to address it aside from modding the vehicle by putting in something like a fuel cutoff button to manually disable the engine without the key?
(first post, btw, cool site)
-Jesse
Old 04-25-2008, 04:29 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Hi Jesse -
First, welcome to the site.
Second, glad you tried this in a parking lot and not on the road! Seriously. I bet there was some adrenaline.
I made a kill switch for my car, though I also use the technique in other cars without one. I can't say that I've ever mistakenly turned to "OFF" and locked the steering, but like most driving tasks it'll probably take a lot of repetition before the correct way to do it becomes a habit.
Aside from the kill switch, I can't think of any other easy "fix" for the problem other than careful repetition.
And I wouldn't recommend using the technique if you're not 100% comfortable with it and understand the potential risks. (It sounds like you're aware )
Old 04-25-2008, 04:30 PM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Hello and welcome to the site Jesse.
I hate to say it, but your doing it wrong. The proper procedure for EOC has been talked about a few times. Here is a link:
http://forum.ecomodder.com/showthread.php?t=1388
Old 04-25-2008, 04:35 PM   #4 (permalink)
I know I was doing it wrong (obviously) but I'm just saying that it was really easy to turn the key the extra click and get it wrong. Just a word of caution to those who might attempt it I suppose.
Old 04-25-2008, 09:56 PM   #5 (permalink)
The first time I tried it I turned it to Lock and removed the key (!)... it was just my automatic 'turn it off' move. I was just rolling to a stop, but it's probably better to practice while you're sitting still a few times. You get used to it very quickly, and there's zero chance of screwing it up once you've done it a few times. A kill switch is still better, just because key assemblies are very expensive.
Old 04-25-2008, 09:56 PM   #6 (permalink)
is awesome
I took out the steering lock in my lumina. It was pretty simple, but I do think a kill switch would be easier to install.
KU School of Engineering
'72 Datsun 240z
'96 Chevy lumina
Old 04-25-2008, 11:11 PM   #7 (permalink)
Randy - removing the key: that's funny!
Somewhat related: on 3 occasions I've disconnected the main battery pack cable in the electric car by pressing the clutch pedal, which is rigged as the emergency shut off. Each time I did it was an "automatic" combo move: get in, seatbelt on, insert key and depress the clutch. Also each time I was also either tired or distracted.
Old 04-28-2008, 10:34 AM   #8 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
Even standard driving is not safe if the driver is tired or distracted.
What I like best about ecomodders and hypermilers is that they just plain pay more attention!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 04-28-2008, 11:06 AM   #9 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 j30
90 day: 22.74 mpg (US)
Also as a side note, if you do put in a seperate kill switch, you're better off putting in something that kills your spark, instead of your fuel. Interrupting the tach wire going into your distributer is always a safe bet.. assuming you have a distributer, of course. If you do decide to go this route, I can give you the wire color and location of this wire if you provide me with your year, make, and model.
Old 04-28-2008, 12:46 PM   #10 (permalink)
Eco Noob
Doofus McFancypants's Avatar
Red Rover - '01 Altima GXE
90 day: 30.07 mpg (US)
Welcome
my first EOC was rough. was on the road - granted there was no one aroung me but it was not in a parking lot - really stupid on my part.
To this day i am unsure what i did wrong, but i poped the clutch and the engine did not fire up. had to stop car then start with key.
I THINK it was miss-keyed and not "ON".
but after that ( and several lower speed checks in my development) the pattern becomes almost habit.
Steve
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
Pulse & Glide / EOC: Anyone rated their gallons per hour @ 0mph? dissimilation Hypermiling / EcoDriver's Ed 27 07-19-2010 04:12 AM
Eoc? (Problem restarting) Pillzilla Hypermiling / EcoDriver's Ed 7 03-12-2008 02:56 PM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 02:18 PM
Brakes, EOC (engine off coasting) and reserve vacuum Lazarus Hypermiling / EcoDriver's Ed 5 01-24-2008 09:17 PM
Pulse and glide with Caravan automatic (actually EOC) popimp Hypermiling / EcoDriver's Ed 20 12-29-2007 02:10 AM
