Old 06-17-2008, 03:12 PM   #21 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Civic DX
90 day: 33.29 mpg (US)
Recently I have not been doing EOC because I've been doing some experimenting with coasting in gear vs. in neutral to see which gets me better millage (I think I have a fuel cutoff while coasting in gear based on data so far). However, if I had to guess, on my way to work, traffic permitting and when I'm not on my bicycle, I probably EOC about 50-60% of the time on the way there, and almost never on the way back because the way there is a nice rolling downhill while the other is just the opposite so I take the highway to avoid the hilly ride home.
Old 06-17-2008, 04:10 PM   #22 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
I'm not sure, but I'd guess my engine is off about 50% of my commute. It's probably more like 60 on 40 off for highway trips.
It's absolutely a benefit during the warmup segment. The engine will use much more fuel for the time it's running, so if you minimize that and make full use of the time it IS on, in a pulse, your overall will be better. The first couple miles are critical to a good trip - make or break it.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 06-17-2008, 05:20 PM   #23 (permalink)
Baz - '93 106
90 day: 62.39 mpg (US)
Originally Posted by rocket View Post
brakes lights are not tied to the ignition ckt; they ALWAYS work. Try it when you go to start your car next. before putting the key in, step on your brakes and look for the reflection or glow of the lights. turn signals, on the other hand, are will not work w/o the key in run
Back on topic: i EOC for about 8 miles of my 50 mile round-trip to work.
It's not the same on my car.
Goal: 3L/100KM
Old 06-17-2008, 10:06 PM   #24 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 j30
90 day: 22.74 mpg (US)
He's right. There's a lot of cars nowadays that the ign circuit has to be on in order for the brake lights to work. GM specifically loves to do this on all new cars.
Old 06-17-2008, 10:41 PM   #25 (permalink)
Scooter - '06 Aveo Barebones!
90 day: 38.64 mpg (US)
Eoc
I could have sworn that the how to I read here about EOC said to turn off the engine, then turn the key back to the on position so that airbags, odometer and other electronics would be on. Am I not correct? Some peeps getting 40% of their drive EOC? WOW, don't think that would be possible with 15 of my 18 mile one way drive to work on the expressway. Trying to figure out if going to the side streets and braving the traffic lights would be that much better or not. I was thinking not. Any suggestions?
Old 06-26-2008, 11:02 PM   #26 (permalink)
dwendt1978's Avatar
Dragon - '93 Metro XFI
90 day: 51.13 mpg (US)
Well I made it 525 miles in a Metro before filling! With 138 miles EOC. Figured out to 62.5 mpg's!!!!
Hell, I'll take it. I try to shut off at 55-60 and coast down to 15 or so. This tank it's gonna be 60 down to 25. And I'm not keeping track of it.
Anyway just wanted to say that it does work.
Old 06-27-2008, 10:08 AM   #27 (permalink)
Baz - '93 106
Regarding the ICE cutting off its fuel supply when coasting - I assume my 1993 diesel engine does this, but I'm not 100% sure. I've been meaning to find out if it actually does. Can anyone point me in the right direction? It'sa Peugeot TUD3 if that helps.
Goal: 3L/100KM
The acetone test trikkonceptz EcoModding Central 88 06-16-2008 10:27 PM
EOC fuel usage ?'s reformed EcoModding Central 4 06-12-2008 08:51 PM
new to EOC homeworkhome53 Hypermiling / EcoDriver's Ed 12 06-05-2008 12:09 PM
First tank w SG homeworkhome53 Instrumentation 3 04-13-2008 11:57 PM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 01:18 PM
