Old 07-22-2008, 06:43 PM   #1 (permalink)
Kawi - '04 Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Monte Carlo Z34
90 day: 26.52 mpg (US)
EOC on motorcycle
Apparently my motorcycle is not the greatest to EOC on. Although I still do it quite a bit, it takes the most convenient vehicle to EOC or P&G and makes it very inefficient. It still works, but I find that I can’t coast nearly as far as my wife’s Hyundai Elantra. It probably has a lot to do with the momentum.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 07-22-2008, 06:47 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Same here, it got better when I upped my PSI. The cars glide farther at higher speeds (say above 10mph) and the bike glides farther at lower speeds (< ~10mph) , Aero has a lot to do with it I'm pretty sure. I also noticed I don't scrub off as much speed on the corners on the bike it seems.
Old 07-22-2008, 07:34 PM   #3 (permalink)
Well with a bike you can take turns at a larger radius than a car (not as wide) and so you don't have to kill the speed as much. The aero of a bike is terrible. Although it is good that I can draft at 3 seconds behind almost anyone and feel a difference.
Old 07-23-2008, 11:53 AM   #4 (permalink)
Mechanical Engineer
The Truck - '02 Ram 1500 SLT Sport
90 day: 17.57 mpg (US)
The Van 2 - '06 Odyssey EX
90 day: 18.48 mpg (US)
The fact that you can easily feel a difference while drafting means that your aero is awful. The more aero a vehicle is the more extreme draft will be required to detect a perceptible difference.
I think you were initially correct when you mentioned both aero and momentum. I think if you took a look at your CdA/mass ratio it will be the defining factor it how well/how far you can EOC at highway speeds. Higher weight and lower CdA will coast further; higher CdA and lower weight will not coast as far.
Motorcycles have horrific Cd, but low A. Both are rather rider-dependent, as is the running weight. Knowing little about bikes, I'll go with some assumptions that between rider and bike you're looking at 1000 lbs, Cd of .5 and half the area of a car. Your car let's say has a Cd of .35 and a weight of 3000 lbs. Your CdA/mass ratio of the car would be 1.17x*10^-4 (x being your total area of the car) while your motorcycle would be 2.5x*10^-4. Since your bike has the higher CdA/mass ratio it will decelerate more quickly than the car (higher drag per momentum). Even if the bike had only 1/4 the area of the car you are still marginally higher on CdA/mass ratio, which will get even worse with a lighter bike or fewer BigMacs. It's not purely scientific and won't help you calculate your actual deceleration, but it's a good method of determining the trend.
You are correct though that at low speeds the vehicle with less rolling resistance (the bike) should coast better.
Electric Motorcycle conversion bennelson Fossil Fuel Free 276 01-27-2012 11:24 AM
Best MPG with EOC & without EOC xbUser Hypermiling / EcoDriver's Ed 21 08-22-2008 12:25 AM
EOC fuel usage ?'s reformed EcoModding Central 4 06-12-2008 09:51 PM
new to EOC homeworkhome53 Hypermiling / EcoDriver's Ed 12 06-05-2008 01:09 PM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 02:18 PM
