Old 09-13-2009, 02:24 AM   #11 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Originally Posted by BackroadBomber View Post
Hi, you wouldn't happen do have a subwoofer or any additional electrical devices in the car, would you? My one friend had a saturn with a subwoofer in it and the saturn transmission has some sort of electronic shift assist or something and my buddies car would never shift right and throw a cel (don't remember what code) if his system was on, even when it was on low power.
Nope, and the sub/amp probably wasn't his problem, so much as how/where it was wired.
My best guess for the service wrench is the CC module, since the two lights associated with it work, and the ECT is brand new ( and the coolant temp gauge is correct).
"żʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux ętre heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 09-13-2009, 03:24 AM   #12 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Those coasting distances are way gooder than I've ever done.
Do that route in the other direction and see how it goes.
Old 09-13-2009, 03:28 AM   #13 (permalink)
It shouldn't be too bad, on another part of the same route, going the other direction. Obviously, I won't do so well in the other direction, as it's a downhill preference.
I was just pointing out that the Saturn coasts like a dream.
If I get a chance before winter, I'm going to do a EOC coast down test on the flats, since there's a marked 1/4 mile there.
Old 09-13-2009, 06:21 AM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Originally Posted by Christ View Post
The car doesn't run right, so instead of coasting in neutral (watching the RPMs jump to 2k+)...
The quick fix for a saturn (and maybe others) is to warm it up, turn on some accessories, and while it is idling good, unplug the idle control valve connector (lower plug by the throttle body/firewall). Then use your foot for idle speed control when it is cold
Old 09-13-2009, 01:13 PM   #15 (permalink)
I did that in my Civic for awhile, until I ended up just opening the throttle plate a bit and blocking off the IACV.
Alas, it's the wife's car... she'd never go for that.
Old 09-13-2009, 01:19 PM   #16 (permalink)
dcb
needs more cowbell
dcb's Avatar
Did your civic rev it up to 2k rpm when coasting? I thought it was just some saturn idiocy. Well it is conceivable to take one of those atmega chips (whatever) and make a better idle speed controller, I've just never gotten around to it, want to get my cruise control back first (97 computer with a 92 stick shift), will probably recruit a microcontroller for that, read the resistive buttons plus whatever else, and control the pedal.
Old 09-13-2009, 01:25 PM   #17 (permalink)
My Civic did the IAC dance... it would rev to 1400RPM, then cut fuel and drop back to 775, then rev up, then drop, then rev up, then drop. I could let the clutch out in gear, and it would drive the car up to 1400 RPM, then cut fuel.
It's two things that cause it on the Civic - TPS and IACV. The IACV only works if the TPS is at or below 1%, to keep the engine idling. When the TPS gives the wrong signal, or the IACV isn't adjusted properly, the CAS (crank angle sensor) and TPS start talking to each other, and notice that the engine is getting up to unreasonable idle speeds. Once they get to the DFCO point (1400 RPM), the ECU reads the signal, cuts the fuel, and the engine speed drops.
Lather, rinse, repeat.
I don't think the Saturn has quite the same feedback loop, but the symptoms are close.
Also, the Civic, like most other cars, does increase idle when moving under no load, but not 2k.
I think I'm going to figure out why it's doing it in the first place before I start working magic on it.
automatic, ecotec, engine off coasting, eoc, saturn
EOC and bad mpg... 97Cavalier Hypermiling / EcoDriver's Ed 10 05-05-2009 09:23 AM
Question about EOC with an Auto... :confused: LastBoyScout Hypermiling / EcoDriver's Ed 20 08-30-2008 07:28 PM
Best MPG with EOC & without EOC xbUser Hypermiling / EcoDriver's Ed 21 08-22-2008 12:25 AM
EOC fuel usage ?'s reformed EcoModding Central 4 06-12-2008 09:51 PM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 02:18 PM
