Most conventional transmission have oil pump driven off inputshaft which spins with torque converter/flywheel.
So if engine is off then no oil pressure but for real short periods it might be ok, but I wouldn't risk it personally .
Edit: to be more specific the pump is driven from converter housing which is same as flywheel/crank, so even before inputshaft/torque converter output
The problem with neutral is the injectors are still firing where if you just left in gear (D) and let off gas injectors shut down on modern engine management systems until you hit idle speed .
