Hi Racer X, welcome to ecomodder!
Can you clarify one thing? You mentioned that "you couldn't find neutral". When you killed the engine at 90mph, with no aero penalty as you noted, did you just pull in the clutch and hold it? Or did you dig down into neutral? Or did you add a neutral detent under top gear maybe?
