Old 05-31-2011, 05:47 PM   #1 (permalink)
sendler's Avatar
Honda CBR250R FI Single - '011 CBR250R
90 day: 92.93 mpg (US)
Ninja 250R SE Green - '09 Ninja 250R SE
90 day: 65.9 mpg (US)
2001 Honda Insight stick - '01 Insight manual
90 day: 60.68 mpg (US)
2009 Honda Fit auto - '09 Fit Auto
90 day: 32.56 mpg (US)
Kawi Ninja650 - '07 Ninja650
90 day: 65.5 mpg (US)
EOC warning
Engine off coasting with motorcycles can ruin the transmission as many have engine oil pressurized lubrication systems as a ninja250 owner found out the hard way when coasting down on the dyno with the engine off.
I would post the link to the Ninjette forum so you could ask him about it but I am locked out from posting links.
Old 05-31-2011, 05:49 PM   #2 (permalink)
sendler's Avatar
link
Search the Ninjette forum for Dyno Run on my 09 SE Ninja 250R
Old 05-31-2011, 06:23 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Bummed today, I think I toasted my clutch
duly noted, guy says if you tow a ninja 250 without taking off the chain it will lock up within 10 minutes. Still it should be able to handle some coasting alternating with a running engine.
Old 05-31-2011, 06:45 PM   #4 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Of course if the engine is idleing you should be able to let it coast out of gear for hours without causing any issues, right?
My Honda's have, for the most part, ball bearings on all of the shafts and the little bit of oil that is in there should be able to handle running with the few drops of oil that is left after you shut the engine off.
Old 05-31-2011, 09:20 PM   #5 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
I usually just pull the clutch lever in and coast in gear, with the engine running. Don't see how that could be a problem. I was thinking about shutting the engine off, but after reading this I am glad I didn't.
regards
Mech
Old 05-31-2011, 10:11 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
I'm not worried about it for coasting a block at a time. Why would it weld up with no load on it?
Old 05-31-2011, 11:26 PM   #7 (permalink)
sendler's Avatar
30s
His trans made it for 30 seconds of coasting down on the dyno with the engine off. He tore it down and found 5th gear welded to the shaft. All of the other dyno videos I have seen show the rider blipping the throttle of a running engine all the while as they slowly brake the drum in order to lube the trans. Coasting at idle with the clutch in is no problem.
Old 06-01-2011, 01:37 AM   #8 (permalink)
alvaro84's Avatar
Teresa - '04 F650CS
Motorcycle
90 day: 81.08 mpg (US)
I often coast more than 30s with Teresa, both engine on and off, mostly with clutch in, rarely in neutral. I've been doing this for several tens of thousands of kilometers.
No problem so far, but she's a different bike, so it may not apply to the Ninjette (Teresa is a BMW F650CS).
Old 06-01-2011, 10:00 AM   #9 (permalink)
sendler's Avatar
pressure lube
Some bikes use engine oil pressure to lube the trans. Some use a splash lube and wouldn't care about coasting with the engine off as much. If the trans seizes from EOC, it can lock the rear wheel sending you down.
Old 06-01-2011, 10:47 AM   #10 (permalink)
dcb
needs more cowbell
dcb's Avatar
Yes, any rider is aware of the ramifications of the engine or trans locking up (another reason why it is good to have the clutch on the output). I'm just trying to understand the conditions under which this happened and determine if the diagnosis is accurate, lots of folks have gone lots of miles EOC on bikes with no reports like this.
Also, you could provide some sort of link, leave off the http, so we are on the same page. The guy I read about was using nitrous on a 250 on a dyno, no suprise that stuff is breaking.
