Old 11-25-2009, 04:42 PM   #1 (permalink)
Efficiency freak
Bearleener's Avatar
Frugolf - '96 Golf wagon
90 day: 40.36 mpg (US)
EOC <> zero fuel consumption
I've been having problems with my car's anti-theft system and wonder if it's got something to do with my frequent engine-off coasting (EOC) stops and starts (see separate thread). Maybe I should do engine-on coasting instead.
So I'm looking for excuses why it wouldn't be so bad to leave the engine on during coasting and at stoplights, if I could get myself to do it.
The fact is, you pay a little bit for the zero consumption during EOC the next time the engine is on:
During EOC the ignition and all electrical accessories are still on, say the ECU, fuel pump, etc. (200 W), headlights (200 W), blower fan on 1st stop (50 W), radio (50 W ?), i.e. a total of about 500 W. You're not using fuel during EOC, but the engine has to make up for the electrical power over the alternator the next time it's on.
Assuming a gasoline engine with an efficiency of 29%, running an alternator with an efficiency of 55%, charging a battery with an efficiency of 90%, the total power consumed by the engine to run all the electric stuff is:
500 W / 0.29 / 0.55 / 0.90 = 3.48 kW, wow, that's 4.7 hp!
(BTW, when the engine's on the battery efficiency factor wouldn't be there because power is coming directly from the alternator.)
So per hour you need 3.48 kWh of energy. Gasoline has an energy density of about 8.9 kWh/l, so that's 0.391 l/h (0.1 gph).
So if the engine needs about 1 l/h to idle (albeit without headlights, fan & radio), then a whopping 39% of it is for running electric stuff; without lights & accessories it's 16%. But that also means that having the engine off uses at least 84% less.
On my 24-km commute the engine is off for about 9 of the 30 minutes. I'm currently getting about 6 l/100km, or about 1.44 litres per commute. The difference between engine-on and engine-off coasting & idling is then
(9/60 h)*0.84 l/h = 0.126 l, which is 8.8 % more with the engine on. In my case that's 0.53 l/100 km or 3 mpg worse. (Disregarding the above electrical power effect it would have been 10.4 %.)
Moral of the story: even considering the electrical power effect, if you can, shutting off the engine is significantly better than letting it idle. But we already knew that.
What the heck, I'll just let my anti-theft system konk out periodically.
You ever notice that birds pulse & glide, too?
Old 11-25-2009, 04:59 PM   #2 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Last time I tested it my ECU, fuel pump and everything drew 80 watts total, the head lights are 55/65 watt bulbs (high/low) each so 110 watts for the pair, running lights are 5 watts each, blower, I think was 15/25/40/60 watts, my Alpine CD player draws 15-25 watts depending on if it's volume.
So almost exactly half of what you quoted, if you are driving at night with the radio and heat on.
Old 11-26-2009, 08:26 AM   #3 (permalink)
Efficiency freak
Bearleener's Avatar
Yeah, MetroMPG referred me to his thread on measurements of power on his Metro. An amazingly low 60 W to run the (3-cylinder) engine, etc. Very enlightening & encouraging.
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 07:18 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 02:29 PM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 05:31 PM
