Old 07-13-2008, 12:46 PM   #11 (permalink)
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
I always thought the last gen EPA ratings were pretty accurate. The new ones "legitimize" the asinine driving of today.
x3 - their "highway" and "high speed" tests aren't what I call highway. If I drove 50 "highway" miles, I would assume 49 miles at 55+ mph and 1 mile of side roads, onramps, and offramps.
From the epa (fueleconomy.gov) website:
Highway test:
High Speed (modern test): (this reminds me of drag racing in my mustang, lol)
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 07-13-2008, 05:07 PM   #12 (permalink)
The aerodynamics are from a roll-down test done by the manufacturer. They do a curve-fit, ending up with 3 parameters (A,B,C) that they send to the EPA. That plus actual weight is all the dyno needs. I think the 'set' parameters are to compensate for the roll-down on the dyno itself.
You can see these on the detailed test data at this EPA page. Obviously this doesn't take into account hills, but I think that's why the tests speed up and slow down so much... it's like going over hills.
The only question is: what exactly are A, B, and C? They're never really defined by the EPA. Edit: see below for an improved guess at the formula.
Old 07-13-2008, 05:17 PM   #13 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
Cool! Found my car's data...and now I don't know what to do with all these numbers staring back at me.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-13-2008, 07:19 PM   #14 (permalink)
I think I finally figured it out from an example in this paper. The target parameters are in pounds, pounds per mph, and pounds per mph squared. So F=A+Bv+Cv^2, where F is in pounds-force and v is in mph.
So power at a particular speed would be P = (Av + Bv^2 + Cv^3)/375, where P is horsepower and v is mph. This seems reasonable... about 40 hp at 60mph for the worst SUV's, about 15 for the best cars.
Aerodynamics Seminar #1 - by Phil Knox MetroMPG Aerodynamics 5 07-12-2008 04:12 AM
Need help for EPA rating to correctly register my megane groar Hypermiling / EcoDriver's Ed 4 06-30-2008 12:30 PM
Aerodynamics Seminar # 5 - by Phil Knox MetroMPG Aerodynamics 4 01-29-2008 01:41 PM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
Aerodynamics Seminar #2 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:06 PM
