06-22-2009, 04:00 PM
#21 (permalink)
Giant Moving Eco-Wall
Originally Posted by shovel
heh... yeah SODAS... after spending a week in Florida (leaving today) I'm pretty sure most of this state's drivers are drinking some kind of frosty cold beverage all right
Wow, when I went to North Carolina's Outer Banks... Holy cow everyone had to be drinkin somethin.
Originally Posted by CobraBall
If only someone would invent an "Obnoxious Subwoofer Canceling System".
uh... heh heh.. about that
I don't know about in your neighborhood, but in California and Arizona pretty much every city has noise ordinances and generally weeks go by between times I hear someone blasting their car stereo. It does me no harm.
What I do hear constantly is harleys with straight pipes, and they're WAY WAY louder than most car stereos. Sure, loud pipes save lives... but they don't have to be THAT loud.
The way I see it, everyone does something that annoys others. I don't like to smell flatulence, but people do it, and that's OK. I don't like to hear harleys, but people ride them and that's OK. I don't like to drive behind a slowass, but people do it, and that's OK.
Freedom for anyone means freedom for everyone and as long as they're not doing you tangible, physical harm or interrupting your food supply or your own freedom, we should all simply accept that we have to let others have their fun too. If NOBODY stepped on anyone's toes once in a while that would mean we all were locked in a cage, because at some point every single one of us annoys someone else with something we're doing, or something we're causing.
That is so true!!!
I agree though, Harley's don't need to be that loud. Just loud enough where I know where he is when I'm driving.
06-22-2009, 04:16 PM
#22 (permalink)
Aviation has had noise-cancelling headsets for over a decade. Much lighter and more effective than heavy sound-deadening material. You are beginning to see snoise-cancelling headsets on target ranges, where hearing loss is a real problem.
I don't think the technology is all that exotic these days.
Might be a real boon for diesels.
Might be a necessity in the beercans we might be driving in the future.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
06-22-2009, 04:37 PM
#23 (permalink)
It is illegal to drive with earplugs, ear buds, or headphones on while driving a motor vehicle. Learned that in Driver's ed. Someone in my class argued over that fact, as well as arguing over using them for cell phone conversations.
06-22-2009, 10:04 PM
#25 (permalink)
The output isn't important what the output is - headphones or speakers - the technology is the same.
4" Slam
02-22-2011, 11:11 AM
#26 (permalink)
Thread revival:
More detailed article posted about the noise cancellation / MPG interaction, this time for the GMC Terrain crossover (badge sibling of the Equinox):
(Note: EPA-rated 32 mpg (US) highway )
When GM engineers set out to deliver segment-leading fuel economy on Terrain they chose to lower the 6-speed transmission's gear shift points to enable the Ecotec 2.4L four-cylinder engine to run at lower rpm torque. In this "Eco" mode, which the driver can activate with a click of a button on the console, the torque converter clutch engages at lower engine speeds to help save gas. While the engineering action improved fuel efficiency by up to one mpg, it also created an objectionable low-end frequency boom. To counteract that boom the engineers turned to active noise cancellation technology.
source: High-End Audio Technology Helps Terrain Get Top MPGs -- DETROIT, Feb. 22, 2011 /PRNewswire/ --
(Article outlines other ecomods to the vehicle to boost MPG.)
02-22-2011, 12:01 PM
#27 (permalink)
Do you want something causing a low frequency boom on your car in return for 1 MPG ?
