Old 10-27-2008, 06:19 PM   #11 (permalink)
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
Last 3: 25.94 mpg (US)
One ethanol reference...
Here's another one for you, Denis. I had forgotten about the issue with ethanol absorbing water, and releasing it, within a system. Maybe that was what GM was warning us techs about so long ago, and it may be temperature related, but our beloved Wiki explains it all right here: Ethanol fuel - Wikipedia, the free encyclopedia
That would be section 9.1 for the fuel issues with cars...and boats...and German cars!!!
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Old 10-27-2008, 06:34 PM   #12 (permalink)
Intrigued's Avatar
Reading farther...
Hmmm... okay, reading farther into Lazarus' wiki link, it is saying that post 1988 cars are generally okay with up to E-20, and post 1995 good with E-85. Now I'm wishing I'd read that in the first place.
Thanks, Lazarus! I wish I were more thorough in reading all of this stuff in the first place: it would have saved me a couple of posts...
Old 10-27-2008, 08:56 PM   #13 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
Keep in mind that it is wiki. You can google E85 in conventional engines and find all kinds of forums and info from folks that have been running it for quite some time.
I think Minnesota is going to E20 pretty soon so that should tell you that at the least E20 should be ok in most cars.
My break even point cost wise was at E50. That's were the decrease in FE (10%) caught up with the cheaper fuel here.
"Judge a person by their questions rather than their answers."
Old 05-18-2011, 03:13 PM   #14 (permalink)
I've Been AeroHauled
Long term affects of E85 are fuel injectors problems and rusting of gas tank. Pop Mechanics did a great article on it. E10 is bad enough.
Old 05-18-2011, 03:17 PM   #15 (permalink)
Got an question. New to this. When people are doing their mileage performance checks, do they factor in E10 vs E0 fuels types. E10 gas has less energy per gallon.
Old 05-22-2011, 01:17 AM   #16 (permalink)
Ethanol Fan
Mr. Fox - '91 Mustang GT
90 day: 15.99 mpg (US)
It's the o-rings that are most susceptible to failure, unless the fuel injector clogs. And the fuel tank would need to be made out of steel to rust. Some fuel tanks are polymer(plastic) in which that would not be the case unless they were nylon which is susceptible to corrosion, I believe.
Another thing you missed is the fuel filters are prone to clogging after switching to a high % ethanol/gasoline blend. It might need to be changed within the next 500 miles afterward.
Good stuff here. I hear all the time about Ethanol being bad for old cars or even cars in general. It's good to see some proper conversions exist!
I'm still hoping to make my next car a custom flexfuel setup and I'm leaning more towards a post CAN bus ECU. Thanks for the encouragement about EFI engines . I kid I kid. The biggest difference is that the ECU fuel and spark maps would need to be adjusted and usually tuners(tool) are $$$ and then getting someone to tune it is $$$ for dyno time and labour. Not to mention that ECU map adjusting is exponentially more complicated than tuning a carbeurator . It's perfect for someone who loves to do that kind of thing, like me .
~Allch Chcar
Old 05-31-2011, 05:14 PM   #17 (permalink)
I shouldn't presume to speak for others on this, but I'm pretty sure the performance is:
Total miles / total gallons
If you start futzing with "equivalent amount" figures, then you open the door for lots of bad math and bad data. You can even get to the infamous 100 MPG Mustang that way. (Hint: Run E85 and only count the gasoline burned; it's not hard to get to 100 MPG that way.)
-soD
Ethanol takes another hit Lazarus General Efficiency Discussion 19 05-30-2011 06:40 AM
[Article] Better Fuel Economy with Ethanol? SVOboy General Efficiency Discussion 62 04-02-2010 11:31 AM
Ethanol kills grain food market WaxyChicken The Lounge 14 12-11-2008 10:07 PM
Ethanol - why not just ride a horse? hvatum General Efficiency Discussion 18 07-16-2008 11:33 PM
Newcomer - 1995 Ford Aspire Ethanol cbergeron Introductions 20 07-09-2008 11:52 PM
