Old 01-09-2018, 12:02 AM   #1 (permalink)
Thumbs up EV Aircraft!
I love this, especially the silence! No- especially how quick and cheap the maintenance will become!
Moar battery capacity and they'd really have something!
https://newatlas.com/electric-aircra...9e053-90350850
Old 01-09-2018, 01:12 PM   #2 (permalink)
Ecomuggler
90 day: 36.05 mpg (US)
90 day: 36.32 mpg (US)
How far can petroleum-powered two-seaters usually go?
Old 01-09-2018, 01:31 PM   #3 (permalink)
Thalmaturge
Eeyore - '04 Honda Civic Hybrid
Go Pod - '00 Honda Insight AC
The Tinyvan - '07 Honda Fit Sport
A Cessna 172 with a 43 gallon tank can go ~650 miles cruising at ~45% throttle (maybe 90-95 mph?).
That's a four seater, but a two seater should be able to do a bit better.
Sam
The Following User Says Thank You to samwichse For This Useful Post:
Xist (01-09-2018)
Old 01-09-2018, 02:32 PM   #4 (permalink)
Piper Cherokee 180 - another 4 place, but with just me aboard - can do about 850 miles at about 75% throttle - that's around 130 mph. But you can find other planes - the Rutan LongEZ, for instance, that are much better on fuel.
Old 01-09-2018, 02:33 PM   #5 (permalink)
Ecomuggler
Wikipedia says this is the electric version of their Trainer, which costs $103,000 (a fraction as much as that Cessna) and has a range of 373 miles, and they started selling the Electro for 69,000€, which is currently around $82,000.
What?
I am trying to establish the ROI.
Also, people comment that most of the noise comes from the propeller.
Old 01-10-2018, 05:51 PM   #6 (permalink)
I'd be concerned about the reliability of the batteries in an all-electric aircraft. Not just it would be exposed to a wide range of variation in pressure and temperature, it's also worth to remind the air-conditioning and pressurization of an aircraft is quite energy-intensive.
Old 01-10-2018, 06:42 PM   #7 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.48 mpg (US)
Tiptoe - '03 Honda Civic Hybrid
90 day: 46.49 mpg (US)
90 day: 51.77 mpg (US)
Lots of small planes don't have any AC whatsoever, or cabin pressurization. You DID notice the absence of seals around those super-skinny doors, right? There's nothing there to hold any air in, and insufficient structure to hold any pressure even if there were seals. This thing's intended as an inexpensive-to-operate trainer, so its ceiling will probably be about 10,000 feet/3000 meters.
Get a little distance away from the ground and it cools off anyway. AC is easy enough to leave off.
Guessing at a cruising speed around 90mph (saw 140-157 kmh airspeeds during the vid) would give the plane a 90 mile range with another 45 in reserve. Not much but not nothing, either.
I would be very curious to know how much range solar cells could add.
Take it easy
The Following User Says Thank You to elhigh For This Useful Post:
Xist (01-10-2018)
Old 01-10-2018, 07:51 PM   #8 (permalink)
It may serve reasonably for a small training aircraft, but I was also considering commercial aircraft.
Old 01-11-2018, 02:03 AM   #9 (permalink)
Originally Posted by Old Tele man View Post
Solar panels on wings for "in-flight" recharging?!?!
A possibility. Rutan's Voyager had them. But with this plane's wingspan, it would only be good for just a bit extra range, rather than on-demand power.
Old 01-19-2018, 06:33 PM   #10 (permalink)
An electric paramotor is another alternative if you really want to fly.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
