Old 11-15-2010, 10:50 AM   #11 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Originally Posted by vpoppv View Post
the last thing we need is some dolt plugging in his Leaf and driving off while dragging a charging station behind him!
All of the manufactured EVs (even Ryland's Citicar) are designed so that if they are plugged in, you can't turn them on and drive off.
On a homebuilt electric vehicle, it's easy to leave that circuit out of your design! (My Electro-Metro has that feature, but it's not actually hooked up right now.....)
Also, the charging plug on pretty much all EVs will always be on the front, or the driver's side. That way you can't help but see and notice it.
One my car, I have to unplug it just to squeeze between the car and the wall of the garage!
VPOPPV: I think many of us feel the same way as you. We don't really want these big expensive charging stations, but people don't want to put up due to cost - we really just need an outlet! I'll have to double-check that ChargePoint station, and see if the 240V version also has a 120V jack hidden inside.
MPaulHolmes' link above goes to a web page where a guy is making adapters. They are not horribly expensive. Still, it would be nicer not to have to use one.
Also, keep in mind that "Charging Stations" are NOT CHARGERS. The charger is built into the car. The Charging Station is simply a glorified electric outlet. I only mention this because I often hear non-EVer's getting confused over that.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
The Following 2 Users Say Thank You to bennelson For This Useful Post:
Nevyn (11-15-2010), Ryland (11-15-2010)
Old 11-15-2010, 09:57 PM   #12 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
a normal 120v 15 amp outlet will work for most people anyway, plug in at work for 8 hours and a 12 amp charger will give you 4-6 miles per hour of plug in time or 40 miles of range while at work, drive less then 40 miles to work and you get done with work with a full charge every day.
Old 11-17-2010, 04:42 PM   #13 (permalink)
123
How long would it take to charge an EV like the leaf with a charger like the one I posted if it had 50% or less battery?
Old 11-17-2010, 05:37 PM   #14 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Looks like Chargepoint DOES have a charging station that includes both 120V AND 240V charging. LINK
These stations supply 240V and 30 amps. They call that level two charging.
Nissan says that the car will take a full charge in 8 hours through the onboard 3.3KwH charger.
So, if the battery is half run down, it would be four hours.
Also, if the car is designed for a 100 mile range, and they say it recharges in 8 hours, you can ballpark calculate how many miles you can go per hour of charging. Divide 100 miles by 8 hours, and you get 12.5. So, if you are the movie theater for two hours, and charge while you are there, you can go another 25 miles after that.
My YouTube Videos
Old 11-18-2010, 06:10 AM   #15 (permalink)
Out of my mind, back in 5
Actually Ben, looking at your link it looks like they are ALL level II stations... Ie the J1772 plug that fit's the Leaf gives Level II power and the Level I is a standard plug... Ie they should be usable for all EV's even homebrew... Not as fast as using the 240V power, but just the same...
Old 11-18-2010, 07:22 AM   #16 (permalink)
All About EVs
Hey nice to see some actual Level 2 Stations sprouting up! Which College in Oregon are they at and specifically where in the parking lot?
Thanks for sharing!
HPEV = High Performance Electric Vehicle
Old 11-18-2010, 09:52 AM   #17 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
The link I provided was specifically for one of their stations that provide BOTH level 1 & 2 charging with the standard outlet AND J1772.
Look here at their other products.
Most of their products provide something OTHER than 120V.
I was just glad to see that they had one that could quickly charge a Volt or Leaf and also a simple homebuilt or an NEV.
My YouTube Videos
Old 11-18-2010, 01:12 PM   #18 (permalink)
123
The school is LBCC. I was thinking of realistic driving scenarios its 52 miles from where I live to the coast, a drive I have done many times. Its another 23 miles to get to the closest chargepoint station that's an extra 2hrs of charging just so you could charge. How do you explain to the family they need to go to the "gas station" for the next 6hrs just so they can go home?
Old 11-18-2010, 01:20 PM   #19 (permalink)
Ah... That explains it then... Unfortunately for me, the chance of getting publicly available charging around here in Sweden is as likely as a free Leaf...
Old 11-18-2010, 01:36 PM   #20 (permalink)
123
What! no public EV charging in Sweden. I thought your country was trying to be petrol free?
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
New open source EV website - could use your help revoltev Introductions 1 08-02-2009 10:35 PM
Anybody have an EV info I was looking at a 99 Ford ranger EV or s10 GM EV? 95CHERJUST EcoModding Central 2 06-26-2009 04:17 PM
EV Calulator? lurch Fossil Fuel Free 2 04-14-2009 04:42 PM
Chrysler's New EV Unveiled On CNBC This Morning! rgathright Alternative Transportation 5 02-09-2009 06:54 PM
