Old 12-11-2008, 11:32 AM   #1 (permalink)
The Vue - '03 Vue
90 day: 25.34 mpg (US)
even nasa uses boat-tails
noticed this on the shuttle's rear end on the news yesterday.
shows that the tail doesn't have to be super long with respect to the body, however it should contour to a specified angle.
nasa basjoosed the shuttle
Old 12-11-2008, 11:40 AM   #2 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
I'd bet that saved more fuel in one flight than i use in a year.
Old 12-11-2008, 12:20 PM   #3 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
that picture used more bandwidth than my grandpa uses in one year
well atleast they're catching on. doesn't really matter too much once you get into space, but then again like 90 percent of the fuel used is probably on lift off (or more)
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 12-11-2008, 12:57 PM   #4 (permalink)
Do they just let it blow off when it is time to go?
Old 12-11-2008, 01:33 PM   #5 (permalink)
"Time to go"? You mean on launch? The tail cone is only for ferrying (and it's been used since the first drop tests back in the '70s). When it's launched, the aerodynamics are going to be vastly different, 'cause there's one heck of a lot of high temperature/pressure gas expanding out of that rear end.
Old 12-11-2008, 01:50 PM   #6 (permalink)
Oh, i'm a doofus... clearly they don't launch into space from the top of a plane.
Old 12-11-2008, 01:58 PM   #7 (permalink)
Suzi - '94 Swift GA
90 day: 48.94 mpg (US)
Prius II - '05 Prius Package 6
90 day: 46.51 mpg (US)
Ok, not exactly sure where to start, I know lots of stuff about the Shuttle Transportation System (STS)...
1) That tail has been around since before the STS started flying (they had a prototype Orbiter model (the Enterprise) that they used for aero testing that they piggy-backed on a 747, perhaps this very plane), so most likely NASA didn't take the idea from a fellow EcoModder...
Here is a picture from (I think the 70's or early 80's) that is about the same as above. It shows some of the testing they had to do. In this test they would take the Orbiter up and release it so it could be landed. At the time I don't think they had a means of escaping if anything went wrong, so I guess you just hoped things worked.
2) The STS uses two types of fuel. The Orbiter uses a Liquid Oxygen / Liquid Hydrogen (LOX/LH2) mix, that burns at a more or less constant rate for about 1000 seconds. It also has Reusable Solid Rocket Boosters (RSRBs) that burn at a more or less constant rate for about 125 seconds. The STS uses a lot of fuel at lift off, but it uses that much fuel for a long time... If you really want, I can see about finding a graph that will show the fuel use over time...
3) The Pictures above don't show how the Shuttle takes off. It is just getting a ride back to Florida since it had to land in California due to weather issues. The Orbiter takes off on the back of the External Tank (ET) with two large RSRBs. The RSRB's drop off about 125 seconds into the total burn, and the Orbiter powers it's self and the ET into orbit, where it drops the ET, and the Orbiter continues on it's way to the International Space Station (ISS).
Here is a picture of the STS taking off. You can see the Orbiter piggy-backing on the red/orange ET with the white RSRBs on the side.
Old 12-11-2008, 02:53 PM   #8 (permalink)
Sts
It's better to see the tail from above.It basically respects the angles Mair came up with.When released over Edward's AFB,the boat-tail doubled the glide range.At the same time NASA was playing with the STS they were also out on Roger's Dry Lake riveting boat-tails onto Ford vans.
Old 12-11-2008, 03:09 PM   #9 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
LIES LIES LIES .... nothing but corporate propaganda I tell you, all great ideas come from Ecomodders ... Great line BTW ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 12-11-2008, 03:20 PM   #10 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
And I have PROOF!
(I posted this in another thread about the shuttle boat tail a while back, but I can't find it.)
Boat Tails; Even NASA uses them! bzillins8806 Aerodynamics 12 08-21-2009 11:20 PM
Boat tails trikkonceptz Aerodynamics 9 09-03-2008 12:58 PM
Rear Wheel Boat Tail Fabrication 2003protege Aerodynamics 1 07-24-2008 06:16 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 7 05-31-2008 12:23 AM
Vacuum forming--may be useful for boat tails, etc.. Otto Aerodynamics 12 03-30-2008 02:02 AM
