Old 02-15-2010, 06:41 PM   #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Even shaft seals are getting ecomodded...
Attributing increasingly stringent US fuel economy (CAFE) rules as the motivation for the development...
...one of the largest suppliers of seals for rotating shafts, says it has developed a new design that reduces rotating friction by as much as 75%. If incorporated on all the seals on a typical OEM powertrain—including the engine, transmission, axle and bearing—the new design could improve fuel efficiency by about 2%, according to the supplier.
Source: Shaft Seal Design Boosts Fuel Economy | The Carlovers Magazine
The seal design also apparently:
  • removes the need for a steel pressure ring
  • reduces heat build up, extending life
  • is being used in one un-named new engine
Frank Lee (02-15-2010)
Old 02-15-2010, 06:47 PM   #2 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
That shaft seal is a "bad mother- (shut your mouth!)"...
In all seriousness, it's encouraging to see manufacturers look at more areas of engineering to improve FE. I wonder when we'll find out who is using the new design (and if it's in the NA market)...
Plus, I can't resist bad 70's humor.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 02-15-2010, 09:24 PM   #3 (permalink)
ecomonkey
silver clown - '02 echo 2 door base
90 day: 45.91 mpg (US)
look for the engine with the leaky shaft recall,,,,,,,,,,,,just kidding ,but new stuff scares me. just talkin bout shaft, good reference.
Ecomodded 5MT 2000 Honda Insight for sale in Buffalo. RobertSmalls For Sale 9 10-23-2011 09:38 AM
Strange DC Motor Drive (shaft), advise required treblig Fossil Fuel Free 3 01-08-2009 08:21 PM
Ecomodded Kia Ceed. Factory fit ecomodding!!! Unheard EcoModding Central 15 09-18-2008 08:31 PM
2006 F-250 4wd Auto Diesel ... Ecomodded ? trikkonceptz EcoModding Central 10 08-03-2008 11:19 PM
Who Ecomodded This? justpassntime The Lounge 4 07-31-2008 04:55 PM
