Old 05-28-2008, 08:53 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Simple antenna aero mod
So you want to help your vehicle get better aerodynamics by removing exterior options, but don't want to lose radio reception? Do a simple relocation of your original antenna then. My 1998 Metro radio antenna was broken off and I got tired of listening to the same old CD's all the time. A replacement antenna was cheap enough, but I am Hypermiling here and don't want an external radio mast sticking out of the body. I found a used antenna from an old car at a yard sale for $0.50 cents and decided to get some radio reception finally.
First thing was to remove the "A" pillar trim by pulling it off and sliding the antenna down the pillar. I plugged the antenna into the radio and put the trim piece back on. I decided to have mine stick out slightly to also use it for holding receipts, toll tickets, etc. You then need to find a rubber grommet or piece of plastic to cover the original antenna mounting hole.
Here are a couple pics.................
GeoMetroforum.com - got mpg?
Old 05-28-2008, 09:20 PM   #2 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Nissan Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Plymouth Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
That's beast. I wonder if you can just run a wire using it as an antenna because that is what I have done to my cd player in my room. The wire runs from the player to around my windows and I get better reception than with the little antenna that came with it.
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 05-28-2008, 09:24 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Clever mod - thanks for posting!
Question: is the original antenna accessible through removing the A pillar trim, or does it run inside the pillar?
Old 05-28-2008, 10:47 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Pretty sweet idea, woulda never thought of it, I just took mine out...
Old 05-29-2008, 11:39 AM   #5 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
I just printed out the necessary steps for removing my antenna from the official repair manual for my car. It's 6 pages long and requires removing the head liner, rear seat backs, etc for a total of 35 steps before re-assembly.
I think I'll hold off on this mod until I have a free 3 day weekend Very nifty solution though!
Old 05-29-2008, 05:47 PM   #6 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
my previous car didn't have an antenna so when i wanted a radio i got an internal antenna... it was a bit pricy around 40 euros but worked great so no regrets... basically its sort of a strip that you stick to the top of the front windshield and than run a wire to the radio behind the a pillar liner, as is shown above.
of course if you can get away with a standard antenna on the inside thats even better, but should you run into reception problems you might want to look into these things, they have an internal signal amplifier and imho they're just as good if not superior to normal antenna's
now i'm stuck with a electric telescope antenna... looks cool but i hate the look of it in my mirror... it just screams drag (while in all honesty it's probably not that terrible in perspective.... and i can always leave the radio off, but at some point i'll refit that interior antenna)
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 05-29-2008, 11:57 PM   #7 (permalink)
TheDon's Avatar
Pepper - '87 Mercedes Benz 300D
90 day: 30.42 mpg (US)
My antenna is retractable... woo. It extends to like 2.5 feet! I get great reception
Old 06-02-2008, 09:09 PM   #8 (permalink)
POS - '97 Ford Aspire
90 day: 47 mpg (US)
my '73 el camino has its antenna built into the windshield. would be nice to be able to do it myself
Old 06-02-2008, 11:18 PM   #9 (permalink)
Oil Tycoon
mopo3's Avatar
Siray - '09 Toyota Yaris sedan
90 day: 39.41 mpg (US)
I removed my antenna, it was a simple un-screw style. I took the wire running out of my radio and sliced it with some old speaker wire that was already in the car, and my reception is just fine. My rear defroster is broken so there was always the option of hooking the wire into there to increase the length of the antenna.
http://picasaweb.google.com/matthewm...10700467206594
Old 07-26-2008, 11:05 AM   #10 (permalink)
The Vue - '03 Saturn Vue
90 day: 25.34 mpg (US)
I just discovered that my antenna is manually retractable from like 2' long to nothing. I usually listen to my iPod anyway (direct hook up & control through headunit = awesome)
when its retracted all the way the housing barely sticks out 0.5" from the A pillar anyway
Help with my aero mods: 1.8L 05 Auto Toyota Corolla blackjackel Aerodynamics 73 11-22-2011 09:55 PM
Testing the IAT mod tasdrouille General Efficiency Discussion 6 09-27-2009 04:09 PM
jeep aero mod ideas johnpr Aerodynamics 22 08-27-2008 07:45 PM
my jeep's new aero mod johnpr Aerodynamics 18 02-23-2008 01:44 PM
Another Autospeed aero article: methods for measuring aero drag Daox Aerodynamics 4 02-14-2008 12:34 AM
