Old 07-15-2010, 03:55 PM   #231 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Convertalier - '00 Cavalier Z24 Convertible
90 day: 26.08 mpg (US)
Send a message via AIM to brucey
For anyone worried about overheating their brakes while the wheels are covered up, I can say that mine have been fine so far. I recently towed a 1000lb trailer (with no trailer brakes) 50 miles through WV mountains and had no brake fade at all on cheap pads and cheaper rotors. It was a fine set up except for the bed on the roof.
And I still beat the EPA estimate looking like that!
Daily Driver
Winter Beast
Old 07-16-2010, 12:55 AM   #232 (permalink)
bike4miles's Avatar
Impressive! I still can't get past the appearance but it would be well worth throwing some on for a long drive.
Old 08-11-2010, 11:32 AM   #233 (permalink)
aerobrick - '04 Dakota Quad Cab SXT
Originally Posted by Bror Jace View Post
Power to you, Concrete, but that sounds a bit too complicated.
I am seriously considering buying these instead:
Full Moon Racing Disc Hubcaps, Stylish Look, Great Prices, AutoAmenity.com
Can you put hub caps on stock aluminumn alloy rims? I am about to try some mods to my quad cab and those disc hubcaps look nice.
Don
Old 08-11-2010, 11:39 AM   #234 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
They won't simply snap on, if that's what you're wondering.
You'd need to fabricate a custom solution based on your wheel design, or drill/tap screw holes.
Old 08-25-2010, 01:30 AM   #235 (permalink)
Ohh snap
brucey's Avatar
Well, 4 months and nearly 20,000 miles later I have a small nick in one of the covers. It is not visible from more than 5 feet away. I put a piece of tape over it and gave it a quick coat of more plasti-dip. No other maintenance of any kind has been done to the wheels. Rain, mud, 5 foot grass, and dirt roads don't touch them.
Looks brand new again. This mod will be staying on for the foreseeable future. I also have yet to have a problem with wheel balancing with as little as the tape weighs. The only problem I see right now is convincing a shop to balance the wheels when they do eventually need re-balanced.
Daily Driver
Winter Beast
Old 12-09-2010, 06:31 PM   #236 (permalink)
Ohh snap
brucey's Avatar
Took them off after almost 30K and no sign of problems. I'm super impressed for tape and spray paint. Got some different steel wheels for snow season/tires.
Considering putting on pizza pans since I still have them sitting around somewhere. Other than cutting, did anyone find a way to install them over top wheel weights on the outside of the rim? The steel wheels I have seem to be much better suited for the single bolt method.
Daily Driver
Winter Beast
Old 12-09-2010, 10:26 PM   #237 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
I have pizza pans on my steel wheels, I used three bolts. They have stayed on since September, 4000 + miles
Look for my build thread in the smooth wheel cover section:
Car MPG Efficiency Modifications Main - EcoModder
Old 12-10-2010, 01:35 AM   #238 (permalink)
Ohh snap
brucey's Avatar
Did you just install them over top the wheel weights, or did you cut the pan?
Daily Driver
Winter Beast
Old 12-10-2010, 07:39 AM   #239 (permalink)
old red taco - '02 tacoma regular cab
90 day: 29.49 mpg (US)
i have pizza pans on my truck for about a year and probably 20,000 miles. i have them installed with one bolt in the center and i cut the pans with tin snips around the wheel weights. the notches stop the pans from spinning. the only annoying thing about the pans is they rattle when i hit bumps. [IMG][/IMG]
Old 12-10-2010, 09:22 AM   #240 (permalink)
Wiki Mod
Mine do not come out to the edge (.75" gap) so I did not have to notch them at all. But the notch is a great idea if you only have one bolt.
Mine rattle when I hit bumps too. I tried some plastic tubing over the outer edge and it worked, till the tubing came off (broke epoxy).
So I am just living with the rattle.
