Old 10-10-2011, 11:43 AM   #261 (permalink)
Anybody have the exact outside diameter measurement of such coupe pizza pans?
I'm looking for some that just barely fit inside the bead rim of aluminum wheels, such that the rim supports the pizza pan mounting.
Failing that, may get pizza pans slightly over-sized, and machine their edges down to fit inside the wheel rims.
Old 10-10-2011, 06:34 PM   #262 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
the 16" I got are exactly 16". I just did a new set on my winter tires. I got aluminum rims and drilled and taped all 5 spokes of each rim.
Old 02-03-2012, 01:02 PM   #263 (permalink)
radioranger
Only tried it on one side and the darn truck kept looping around on me!! next paycheck buying two more pizza's or i could use cardboard ones after i eat the pizza during the superbowl . seriously nice work , one trouble the pizza tins are steel and rust pretty easily plastic might be better, how about some of that fiberglass sheeting stuff they use in bathroom paneling ,
Old 02-03-2012, 01:06 PM   #264 (permalink)
radioranger
got another idea, that is so crazy it might be a good one, Since all cars are set up to run straight on a normal highway there is always a tendency to pull towards the shoulder a bit, especially with wear on the parts involved, so the idea, vary the tire pressure a bit say three or four more pounds on the side it's pulling toward, to balance the load on the steering and eliminate the pulll that the power steering pump has to power and use horsepower to fight . any thoughts
Old 02-03-2012, 08:51 PM   #265 (permalink)
Ladogaboy - '011 Lancer EVO GSR
Team Emperor
90 day: 27.18 mpg (US)
E85 EVO - '011 Lancer EVO GSR
90 day: 21.38 mpg (US)
That's why you get aluminum.
Old 04-27-2012, 12:39 AM   #266 (permalink)
PT Cruiser - '01 PT Cruiser Limited Edition
well im very interested in putting moon disks on my car, but im a dork with a wrench and screwdriver...if there is anyone in the omaha or lincoln nebraska area, that is willing to help me with that, i would greatly appreciate it.
WJ
Old 05-23-2012, 10:39 PM   #267 (permalink)
Yep, gettin' started...
ECONORAM - '07 RAM 1500 QC SLT flex-fuel
90 day: 17.82 mpg (US)
the Avenger - '08 Avenger SXT
Last 3: 27.18 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by Thalass View Post
Out of curiosity: Has anyone made transparent wheel covers? That way you'd get to still have nice looking wheels while improving your CoD.
I did--still testing--if I can keep them on the truck. First clear attempt was with 0.100" LEXAN disks. However, I cut them a little too small in diameter...and they moved enough to cause a balance vibration. I used parachute cord to tie them to the wheel spokes because I didn't want to drill holes in the wheel, and the wheels have so much dish I'd need nearly a six inch bolt to hold them from the center. Yep, they started getting scratched up on the edges from all the movement. So did my wheels.
Second clear attempt was with 0.015" LEXAN. This was thin enough to cut with scissors--very convenient. Also thin enough to be rolled up in a box for shipment! Used twine to tie the disks to my wheel spokes. The twine was synthetic and too slick and the knots slipped and the front two covers went flying off. They're somewhere between here and Fort Worth. I also tried nylon zip-ties, but I'm hesitant to continue that as I expect them to wear through the wheel paint.
I've thought about epoxying plastic nuts to the spokes, and using plastic bolts to hold the covers on...or maybe velcro straps that wrap around and through the disk.
I previously tried black corroplast disks with adhesive backed velcro (front ones go flying away), double-sided tape (more fly-aways), and parachute cord.
I have noticed a mpg difference. On the last trip I used the 0.100" disks I removed them half-way between OKC and Wichita Falls. I could only go 65 mph without the disks...where I could go 70 mph with them while maintaining the same mpg. I watched my MPGuino the whole trip...
