Old 09-27-2008, 05:35 PM   #31 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
Time to retape my hubcaps then! Good find tas!
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 09-27-2008, 07:23 PM   #32 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Those aftermarket rims are "air blenders"!
It's interesting to note that the exposed 19 inch rim is the worst case, but when masked, it's the 2nd best case - better than the masked 17 inch rim.
To me that suggests the shrinking gap between tire and wheel arch (you can see the progression in the photos) may be having a beneficial effect. And it may be even more significant if they didn't control for tire width as well (they apparently didn't control for overall circumference, so I'd be surprised if they did control for width).
You are right about the gap reduction. An interesting thing to note is that if all wheels were also blocked from the inside, the 17 inches and 19 inches wheels would do better than the steel rim. The reason for larger taped wheels to perform less than the 15 inches steel wheel with cover is that the disk brake cover most of the wheel opening from inside airflow in the smaller one, wheras there is a huge gap on the larger diameter wheels which increases ventilation resistance a lot. It would have be interesting to see them test something like a 205/75R15 with a steel cover. I'm pretty sure that would have been the best.
The tires tested were 195/65R15, 235/45R17 and 235/35R19.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 09-27-2008, 07:42 PM   #33 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
to argue the very thing that has many dynamics- left rights ups downs and even backwards...weight changes, gforce side winds front winds and brakes doing four different things. Accelerating, decelerating fwd , four wheel drive, auto and manual tranny, hubs or discs, independent suspension, solid axle...heat and torque for given engine curves as well as transaxles or axle enclosed. Electrical dissipation needed or not needed....
alloy or steel is the only question I answer. Keep the hubcaps. Alloys seem to be the champ on anything, unless they are badly made, and that is very rare today I would hope.
It seems comical in comparison to the engines to smooth wheels over a balanced part that needs to simply move every direction...when all engines have a wobbling idiot called a counterbalanced crankshaft. Fix the aero wheels, use a balanced engine. Watch the aero pursuits fade away into ridicule.
Old 09-27-2008, 10:25 PM   #34 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
My tape is still hanging in there.. And after seeing that chart, I'm going to keep my tape!
Cheers,
Rich
Old 09-28-2008, 01:34 AM   #35 (permalink)
Taurus - '99 Taurus SE
90 day: 17.89 mpg (US)
Windstar1 - '97 Windstar Cargo
90 day: 16.99 mpg (US)
Vulcan - '97 Vulcan 750
90 day: 45.96 mpg (US)
Suzuki - '09 SX4 Technology AWD
90 day: 24.62 mpg (US)
hmm im curious is it possible to put on a pizza pan thats bigger than the rim? so that it covers part of the tires?
maybe that will help reduce the gap of tire and rim.
Old 09-28-2008, 08:40 AM   #36 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
After seeing that chart, I'd be going for pizza pans.
Old 09-28-2008, 09:45 AM   #37 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 scenic
90 day: 43.09 mpg (US)
megane - '97 megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Prius
90 day: 55.12 mpg (US)
Originally Posted by tasdrouille View Post
If anyone still had doubts on that one...
Thanks a lot for these data.
What amazes me is the Cd difference with speed. I though that for cars' speeds (30-100 mph) the Cd was constant.
Is the cover has a better result because it's convex while tape masks are flat with some concave parts ?
In first case the air is moved away from wheel arch and turbulence is limited.
SAE paper 2007-01-1047 The Influence of Rotating Wheels on Total Road Load
I wished these documents were free... Wait, they have DRM... argh
SVOBoy, MetroMPG, why not add DRM protection on EM.com ? ;-)
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 09-28-2008, 10:55 AM   #38 (permalink)
So, where can I find some 17" pizza pans with a 1/4" rim??
A perfect 17" would over-lap the gap, and a 0.20" to 0.30" would seal the gap nicely..
Since the center of my steel rims sticks out about 1/4" above the outer edges of the rim,
I'll need to over-lap a flap disc, or buy some 17" OD discs that are concave inside..
Hummm, Hard Aluminum Sloped Side 17" Pizza Pan S17 | Pans Screens Peels And Separators | Pizza items from Wasserstrom
Is ,18 GA ALUM thick enough for this app?
Cheers,
Rich
Old 09-28-2008, 11:09 AM   #39 (permalink)
Tracy - '00 corsa
check out my wheel covers and skirts.
so far its really hard to claim a mpg gain. i think it is working tough. im getting 14.2miles per litre. this is close to my previous best and i was going slightly faster with less drafting.
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 09-29-2008, 10:51 AM   #40 (permalink)
That's what I might try to do (if I buy some pizza pans).
Since the center of my rim sticks out about 1/4 inch.
That center area is where I would need to drill my mounting holes
and a flat disc would be floating about 1/4" above the outside edge of the rim.
So, if I could get the rolled edge of the pan to just kiss the rubber a bit,
I think that might be the perfect solution for my wheel..
What do you guys think about leaving the tape under the pizza pan?
Would it help?
The only problem I can think of, is loose tape balling up on one side
and making the wheel off-balance..
Cheers,
Rich
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/experiment-smooth-wheel-discs-tested-b-4-6-a-4368.html
Posted By For Type Date
AeroProject: L'ardua scelta dei copricerchi This thread Refback 01-24-2012 12:39 PM
Grille blocks on the Focus? - CleanMPG Forums This thread Refback 01-20-2012 12:17 PM
TLC Family "How to Use a Pizza Pie Tin to Improve Fuel Economy" This thread Refback 01-16-2012 09:50 AM
wheel disk covers... MPG myth or not? - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum This thread Refback 01-03-2012 05:43 PM
Hypermiling News, Videos, Reviews and Gossip - Jalopnik This thread Refback 12-27-2011 06:43 PM
Fórum TwingoClube.com • Ver Tópico - ARO PARA TWINGO !? This thread Refback 12-01-2011 10:40 AM
AeroProject: settembre 2011 This thread Refback 11-24-2011 12:32 PM
Underbody Panel - Maxima Forums This thread Refback 11-23-2011 06:47 PM
First road trip on our LEAF | Canadian Leaf This thread Refback 11-12-2011 12:11 AM
Links To Improving MPG « Wave Manifesto This thread Refback 11-02-2011 05:51 PM
New Wheel Covers This thread Refback 10-15-2011 01:19 AM
AeroProject This thread Refback 09-28-2011 01:15 PM
Skoda Felicia Club Polska - Zobacz w?tek - Jak je?dzi? ekonomicznie??Ile pal? Felko? This thread Refback 07-07-2011 04:28 PM
Better MPG on a s14a?? - SXOC Bulletin Board This thread Refback 06-05-2011 01:44 PM
Wheel Skirts This thread Refback 05-26-2011 02:47 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 03-23-2011 04:18 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 03-14-2011 05:11 PM
Tapones de ruedas lisos para mejorar aerodinámica | Kilómetros por litro This thread Refback 01-28-2011 09:53 AM
Sometimes There Is No Title. This thread Refback 01-11-2011 02:51 PM
<![CDATA[Jalopnik: epa, +]]> This thread Refback 12-09-2010 10:23 PM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 06-14-2010 05:06 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 06-14-2010 02:04 PM
How to improve mileage of Honda City (current: 18 kmpl; goal: 23 kmpl)? - Page 11 | Articles | Car Forums - CarWale.com This thread Refback 06-03-2010 06:49 AM
Stainless Smoothies on the Prizm: Pics - Page 2 - Toyota Forums :: Toyota Nation This thread Refback 04-11-2010 12:36 AM
Underbody Panel - Maxima Forums This thread Refback 03-19-2010 09:42 PM
smooth hubcaps - Page 2 - DIY Electric Car Forums This thread Refback 01-05-2010 03:22 PM
Maxima and Cefiro owners down under... - View topic - Ecomodder.com This thread Refback 11-05-2009 05:50 AM
Que Coche Comprarme Barata Y Sobretodo Potente Con Unos 3000€ - Página 2 - ForoCoches This thread Refback 09-24-2009 11:01 AM
Save on Gas: Aerodynamic Wheel Covers This thread Refback 09-13-2009 12:56 PM
