Old 09-29-2008, 12:04 PM   #41 (permalink)
Cool.
This seems like a simple and effective way to improve FE.
However I've noticed one small gotcha. There is no access to the tire's valve cap, so the wonderful new hub cap will have to be removed just to check the tire pressure. That doesn't seem like a good idea, since they could break if repeatedly removed. Especially if you spend $100 on aftermarket hub caps.
Randy
Old 09-29-2008, 12:50 PM   #42 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Denis, Isn't there a renowned aeronautical engineering faculty in Toulouse? I'm pretty sure they would have copies of yearly SAE transactions books at their library, in which case you can probably have free access, at least for on site consultation. Around here just about anyone can walk in a University library at have a look at all the books they have.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 09-29-2008, 08:34 PM   #43 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
Originally Posted by rjstegbauer View Post
Cool.
Randy
I've seen a few guys leave off the valve holes with the bolt-on Moon Disc, but if I get some pizza pans, I'm going to try drilling some holes in them and use a valve extender when I top off the 44 PSI..
Cheers,
Rich
Old 09-29-2008, 10:33 PM   #44 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
Tasdrouille,
Awesome data - like the interesting low speed non-domed anomaly
glad I have my wonderful domed pizza pans
it would be good to understand how that Cd change impacted total drag
did they calculate it in any way a person could directly convert to FE for a similar car
it might help folks understand how significant wheel covers are or are not
.5 mpg improvement is terribly hard to tease out of real life - even with a scan gage
while I recommend smooth covers - I would hate to create too high of expectations
I do not think most modern cars will show a savings without a wind tunnel
wheel wells are tight and tires are flush (suvs and trucks maybe another story)
I attribute my results being more significant because of my large wheel wells & very recessed wheels
at least with the covers the air can re-establish which way it is supposed to be going
In fact I only tested and reported because I noticed a difference
I really did not expect to notice it when I installed them (thus my $20 budget for the design)
Xringer,
you are a man after my own heart (right down to the 44 psi )
attached a picture of my set up - just like you described
Also took the picture in it's natural state (dirty), for those considering clear covers
what does it take to get this splatter - dust, rust and a puddle
clear covers are best left for concept cars
File Type: jpg truck wheel well with smooth cover.jpg (109.6 KB, 800 views)
Concrete
Start where you are - Use what you have - Do what you can.
Old 09-29-2008, 10:55 PM   #45 (permalink)
bluesfan's Avatar
The Bluesmobile - '08 B2300 2WD
90 day: 22.62 mpg (US)
Originally Posted by Concrete View Post
+150 miles later heres the data (raw)
(sorry about the odd table format - got to be abetter way- but I don't know it )
A-B-A average 29.3 mpg with vs. 28.0 mpg without
* scan gage was reset 0.2 miles into course due to possible semi interference, so this run is .2 miles shorter
** I may have punched it too hard on acceleration - the ECU seems to stay in a higher performance/ lower FE mode for ~90 seconds or so after +50TPS - My bad - not very Hypermiler like. very noticable loses in real time at beginning of course - not too much difference in the averages over the course.
Variances noted, but all data is used in findings
Nice work, and sorry for the delay. VBulletin code tags are a better way:
Code:
                                 Outbound          Return                Average
With wheel covers                  28.5             29.2
                                   29.8             30.7
                                   29.2             29.7
                                   29.4             29.8
                                   29.7             30.1                 29.6 mpg
Wheel covers removed               28.0             28.2
                                   28.0             28.5*
                                   28.0             28.2
                                   27.7**           27.7**               28.0 mpg
With wheel covers                  29.0             29.5
                                   28.8             28.0 **
                                   28.7             29.5
                                   28.8	             29.4                 29.0 mpg
Hit the Quote button to see how easy it is.
In reverent quest of the last mpg...
Old 09-29-2008, 11:05 PM   #46 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Hey! I'd take a 1.3 MPG improvement.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 10-09-2008, 08:12 AM   #47 (permalink)
Wheel disks is a topic warm to my heart as there is none that i can attach to a vehicle that will not remain in place. many of you have scan gauges and the one that works for me and is free is my brain gauge.
In all fairness one cannot determine whether the racing disks, moons are effective without first removing the splash shield from the rear of the disk brakes. You may have noted that they are shaped to deflect the rushing air to the brake disks to keep them cool.
The splash shields effectively minimize the aerodynamics of the racing disks and actually cause more drag as the rushing air is trapped behind the racing disk.
I removed my splah guards and the effects were immeadiate, smoother wheel response less road noise and better fuel economy.
there are times when i hear that someone is who is a tad afraid to make any mods for fear that they may ruin thier pretty car, that bieng the case why bother bieng on ecomodders. Might be better to go and polish the car and hope that the gas mileage will improve. Maybe a chrome dipstick will give you the extra miles that you dreamed of.
There are guys here who in the interest of better gas mileage go to extremes and like myself are laughed at. The one thing that they cannot laugh about is the gas mileage that we are getting compared to the squeamish who like things the way they are.
If i were to count all of the people who laughed at my mods i would need a calculator, laugh as they may i know what i am getting per tank or qurater tank that i run on and it is i who has the last laugh.
Best yet is that i have come up with a aerodynamic invention that will turn me a few bucks and that did not come about by bieng squeamish, you either mod or don't bother!
Old 10-09-2008, 08:26 AM   #48 (permalink)
I cannot understand why everyone has to make holes for air stems, glue racing disks, screw them on with every conceivable attachment whereas on hole dead center with a small stainless torx screw does the job, 6,000 miles through rough and smooth roads, snow and mud and they have not moved nary an inch.
Remove the one screw and air the tire , reinstall..........less than four minutes per wheel
Why you guys drill through those cool racing disks for air stems is beyond me, the three point set up sucks as well.............pop on's pop off and easy to steal.
Think out of the box and you will understand what i am talking about..............not sure if the racing disk pix on the crx show up well enough to show how it is done.
CRX is now history, time to move onto something more challenging
Old 10-09-2008, 09:25 AM   #49 (permalink)
99metro's Avatar
putt-putt - '99 Metro Base
90 day: 54.44 mpg (US)
Dusty - '89 Bronco XLT
90 day: 14.62 mpg (US)
Cowboy - '90 Bronco XLT
90 day: 17.42 mpg (US)
HayHauler - '06 3500 ST
90 day: 14.07 mpg (US)
With my low speeds, I doubt they would make much of a difference. If anything, they'd look better than what I have now (nothing). BUT, if they gave me one or two MPG - that would be something. I found some 13 inchers, if anyone was interested for $85:
Racing Disc Pop-On 13 inch
2006 3500 Dodge QC/FB 5.9 handshaker
Old 10-09-2008, 02:58 PM   #50 (permalink)
"Why you guys drill through those cool racing disks for air stems is beyond me, "..
It must be just that guys who want to check their air pressure once a week,
without getting out the tool kit..
Cheers,
Rich
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/experiment-smooth-wheel-discs-tested-b-4-6-a-4368.html
Posted By For Type Date
AeroProject: L'ardua scelta dei copricerchi This thread Refback 01-24-2012 12:39 PM
Grille blocks on the Focus? - CleanMPG Forums This thread Refback 01-20-2012 12:17 PM
TLC Family "How to Use a Pizza Pie Tin to Improve Fuel Economy" This thread Refback 01-16-2012 09:50 AM
wheel disk covers... MPG myth or not? - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum This thread Refback 01-03-2012 05:43 PM
Hypermiling News, Videos, Reviews and Gossip - Jalopnik This thread Refback 12-27-2011 06:43 PM
Fórum TwingoClube.com • Ver Tópico - ARO PARA TWINGO !? This thread Refback 12-01-2011 10:40 AM
AeroProject: settembre 2011 This thread Refback 11-24-2011 12:32 PM
Underbody Panel - Maxima Forums This thread Refback 11-23-2011 06:47 PM
First road trip on our LEAF | Canadian Leaf This thread Refback 11-12-2011 12:11 AM
Links To Improving MPG « Wave Manifesto This thread Refback 11-02-2011 05:51 PM
New Wheel Covers This thread Refback 10-15-2011 01:19 AM
AeroProject This thread Refback 09-28-2011 01:15 PM
Skoda Felicia Club Polska - Zobacz w?tek - Jak je?dzi? ekonomicznie??Ile pal? Felko? This thread Refback 07-07-2011 04:28 PM
Better MPG on a s14a?? - SXOC Bulletin Board This thread Refback 06-05-2011 01:44 PM
Wheel Skirts This thread Refback 05-26-2011 02:47 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 03-23-2011 04:18 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 03-14-2011 05:11 PM
Tapones de ruedas lisos para mejorar aerodinámica | Kilómetros por litro This thread Refback 01-28-2011 09:53 AM
Sometimes There Is No Title. This thread Refback 01-11-2011 02:51 PM
<![CDATA[Jalopnik: epa, +]]> This thread Refback 12-09-2010 10:23 PM
Jalopnik: Obsessed With The Cult Of Cars This thread Refback 06-14-2010 05:06 PM
How To Get 99.7 Mpg From A Geo Metro This thread Refback 06-14-2010 02:04 PM
How to improve mileage of Honda City (current: 18 kmpl; goal: 23 kmpl)? - Page 11 | Articles | Car Forums - CarWale.com This thread Refback 06-03-2010 06:49 AM
Stainless Smoothies on the Prizm: Pics - Page 2 - Toyota Forums :: Toyota Nation This thread Refback 04-11-2010 12:36 AM
Underbody Panel - Maxima Forums This thread Refback 03-19-2010 09:42 PM
smooth hubcaps - Page 2 - DIY Electric Car Forums This thread Refback 01-05-2010 03:22 PM
Maxima and Cefiro owners down under... - View topic - Ecomodder.com This thread Refback 11-05-2009 05:50 AM
Que Coche Comprarme Barata Y Sobretodo Potente Con Unos 3000€ - Página 2 - ForoCoches This thread Refback 09-24-2009 11:01 AM
Save on Gas: Aerodynamic Wheel Covers This thread Refback 09-13-2009 12:56 PM
