Explaination of front wing design
Morning all, Can someone explain the reason for these 'notches' in this wing's gurney flap please? are they vortex generators?
http://i45.tinypic.com/in5zzq.jpg |
They sure look like it.
Serrated edges are becoming a trend in aviation to reduce drag on sharp edges (see Boeing 787 engine nacelles), but in more crude ways, were also used to quieten old 707 engines (which received flower-shaped hush kits that better / quieter mix the air going through the engine, with the air that's been going around the engine nacelle. http://3.bp.blogspot.com/_uRX1wGVlxM...0/hush+kit.jpg or http://www.airliners.net/photos/small/1/9/4/0313491.jpg |
Thanks for reply - so what purpose do these serve only being in the centre?
To reduce buffeting on the GoPro? I don't know. Did you get a chance to talk to the team members? I'd ask them what wind tunnel facility they use.
The video camera mounted on the top, a couple feet behind the front wheels.
Brilliant perspective of the photo may provide a clue to the answer. The car body is beyond, and I suspect the ridges break up a standing wave caused by the down-force vortex which forms following a Gurney Flap.
F1JOURNAL.COM http://www.f1journal.com/photos/gurney_004.jpg My experience on this topic is in acoustics (4-years ago): Do you have a variable splitter plate? - The Virtual Hoverrally - Page 2 Quote:
- reduce buffeting on the car's fuselage, or on the driver's helmet - if it works as far back as the driver's helmet, those 3 circles above the seat are likely intakes ? Then it could help there as well . - maybe even out pressure over the vent hole, rather than have a pulsating effect ? Have you ever driven a motorcycle with an ill-adjusted or ill-conceived screen ? The buffeting is debilitating. One way to solve this buffeting is dimples - which are VG in the gliders' world ;) - near the top of the screen. |
guess
My guess is that without the whale fin tubercules,or raptor feathertips,that there is something about the frequency and amplitude of the shedding vortices approaching the dragsters body that the crew didn't like,so they've altered them with this mod.Which goes with the 'accoustics' comment mentioned by Kachi above.
