Old 11-13-2009, 09:23 AM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
External antenna for cell phone
Does anyone know how to make an external antenna for a cellular phone? The Wife's office is in a place where the cell signal is too weak to talk, only sometimes she can text. I'd like to make an external antenna for her to hang in her office to plug into when she's at her desk.
I've googled around, but nothing of the simple wire loop design If it's any help, her phone is a Nokia.
Thanks
Piwoslaw's Peugeot 307sw modding thread
Old 11-14-2009, 10:36 AM   #2 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.26 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Your frequencies are different than ours so go here to get the lengths you need Antenna Elmer
I cant find the website but you will need to get the connector for the end of the phone, it should be a SMA, then adapt to the coax cable.
Next get 2 3/4" pvc pipe caps and about 2 foot of pvc pipe.
The 14ga copper wire antenna will get soldered to the center of a coax connector that gets threaded into 1 PVC cap.
measure 1/4 wavelength, bend 90deg, make a loop just smaller than the inside of the pipe, then 90 deg bend straight again. Measure 5/8 wavelength and cut.
Encase in pvc pipe to protect and youre done.
Similar antennas are made for wifi reception. Sorry I have to run or I'd google it.
I also made a double bi-quad that worked awesome
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 11-14-2009, 10:47 AM   #3 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
Found it !!!
Home-brew Compact 6dBi Collinear Antenna
Double Biquad Antenna
Much clearer with Marty's pictures.
Dont forget, the lengths will be a few mm different.
Support Bennelson !
The Following User Says Thank You to JasonG For This Useful Post:
Piwoslaw (11-15-2009)
Simple antenna aero mod Johnny Mullet Aerodynamics 62 01-19-2012 10:38 PM
seriously get off the cell phone Compaq888 The Lounge 23 06-18-2010 03:14 AM
Power Antenna Cut-Off? PlaysWithMatches Aerodynamics 10 11-10-2008 04:01 PM
DIY - Removing Your Radio Antenna SVOboy DIY / How-to 27 07-07-2008 08:38 PM
