Old 12-29-2010, 09:39 PM   #1 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
External Combustion Engines
The Cyclone external combustion engine looks pretty interesting; and it would seem to have a high efficiency, given the relatively cool exhaust and very low emissions exhaust and continuous burning.
(click on image for link)
Video: A Steam Engine for Your Car
Could Waste Oil Power Your Range-Extended Electric Car One Day? - Green Car Reports
They are claiming over 30% efficiency -- not bad, but not as good as I hoped. This seems to solve many of the issues we've discussed in the internal combustion engines threads; like burn time, and mechanical torque, while it has simple mechanicals and no transmission required. (Sounds a lot like EV's?)
What do you think?
Old 12-30-2010, 12:41 PM   #2 (permalink)
I think it'd be a lot better just to go to a Stirling cycle engine, which has max theoretical efficiency. If it's in a Volt-type hybrid, then the slow acceleration &c aren't problems.
Old 12-30-2010, 01:09 PM   #3 (permalink)
I are aerodynamic kitteh!
t vago's Avatar
2000 Fiat Dakota Quad Cab - '00 Dakota Quad Cab SLT
90 day: 18.33 mpg (US)
Dakota A-B-A HAI - '00 Dakota Quad Cab SLT
90 day: 19.38 mpg (US)
What sort of fuel does it run on? Snake oil?
2000 Dodge Dakota Quad Cab
2002 Chrysler Sebring Convertible GTC with transplanted 3.5L LH engine
Old 12-30-2010, 05:57 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Neil -
It seems to be liked by a few folks :
The Cyclone Engine was deemed the Invention of the Year for 2008 by Popular Science magazine. It also won awards from the Society of Automotive Engineers in 2006 and 2008.
2008 invention awards | Popular Science
Steam Under the Hood | Popular Science
The Cyclone
Cost to Develop: $2 million
Time: 8 years
As long as the internal combustion engine has been around, garage tinkerers have been trying—in vain—to best it. But Florida boat engineer Harry Schoell, a lifelong inventor with a portfolio of patents, thinks he’s got the answer, in the form of a reinvented steam engine.
But steam engines small enough to fit in a car don’t typically produce enough energy to drive it. Schoell’s design, called the Cyclone Green Revolution Engine, gets more power from the steam by making it so hot that it turns “supercritical,” a stage at which it behaves more like a liquid and expands far more than gaseous steam.
Although it can scale up or down, Schoell’s prototype is roughly the shape and size of a backyard grill’s propane canister. Inside a doughnut-shaped combustion chamber at the top, fuel—be it biodiesel, ethanol or gasoline—combusts with air continuously to create a 2,000°F tornado (hence “Cyclone”). Steam circulates around a heat exchanger until it reaches 1,200°F and then pipes into the engine’s cylinders to drive the pistons. As the steam cools, it’s recycled back into the system and reheated.
Maybe it could be used with the plastic-into-oil gizmo :
Convert Plastic Into Oil
CarloSW2
American Solar Energy Society
Old 12-31-2010, 12:09 AM   #5 (permalink)
Josepha - '08 xD
If snakes had oil, it would do fine; sleazy car salesman's hair grease would probably be fine, as well. It can burn virtually any liquid fuel, according to the designer.
The water is a closed loop if I understand it correctly.
Old 12-31-2010, 11:40 AM   #6 (permalink)
Enormous sized, combined cycle steam can near 50% efficiency, as in modern electric powerplants. However, on a small scale, I'd be surprised to see better than 10%. People have tried for years. The results are always the same, and for very good thermodynamic reasons. The temperature that superheated steam requires demands massive energy input. To extract that energy down to a condensate (efficient recovery of all energy input) has always demanded large, non portable equipment. (for all that expansion).
Old 01-01-2011, 06:50 AM   #7 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
I've made my share of big steam.
It takes a lot of energy to make superheated steam. It ships well however, very little loss a mile away.
The other issue is steam eats metal, heavy cast iron and steel will be needed to make this engine last.
Good looking drawing though.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 01-01-2011, 08:35 AM   #8 (permalink)
Interestingly enough, this company is right down the road from me. I may call them sometime soon and see if I can go by for a look. I'll hold off further judgment until then.
Old 01-01-2011, 08:55 AM   #9 (permalink)
Chug - '96 Polo CL
90 day: 49.42 mpg (US)
THE SIZE OF DARN THING!!!! and that only produces 300+ BHP but it does run on water though so there's the good thing as that that lubricant too.
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 01-01-2011, 09:04 AM   #10 (permalink)
Josepha - '08 xD
They have working units:
They have tested it independently at 30% efficiency.
I wonder about heat up time. If it was used as a serial steam electric, I wonder if some efficiencies could be gained?
