05-09-2009, 07:21 AM
#21 (permalink)
* I feel all this electric pump, or turbo timers are all a little over the top just to avoid 10 seconds of waiting to turn off the engine for me, considering the age of the car.
* Not going to get an EGT gauge. It is nice and might be useful, but I can't justify the $80 minimum cost. I've decided on a boost, oil pressure and voltmeter gauges.
* Dremd - I can't find a boost only gauge *anywhere*, and I'm sure if I do find one, it'd be quite expensive. I don't mind having to live with the vac part that will be unused.
Thanks to everyone for all your help, much appreciated!
My aim: to achieve 3L/100km.
Best tank @ 65mph: 864.2 miles 69.36MPGus 3.4l/100km
05-09-2009, 11:34 AM
#22 (permalink)
aero guerrilla
I read on the Peugeot forum that the turbine in a turbodiesel has some kind of boost sensor (this was a thread about someone's turbo malfunctioning). Can the data from this sensor be utilized, or is it some low level, ECU-only stuff?
Piwoslaw's Peugeot 307sw modding thread
05-09-2009, 01:11 PM
#23 (permalink)
Yes, I just spotted that in my Haynes manual this morning. However, I don't know whether I can tap directly into the sensor or it is using a specific method of communicating the data to the ECU. Not sure how I would be able to find this out.
05-09-2009, 02:39 PM
#24 (permalink)
6 speed Diesel FTW!
That's actually the set my tdi came with. If you keep your eyes peeled you may find a used egt gauge . . .
Amazon.com: VDO 150052 Boost Gauge: Automotive $27
Is the one on my car;
6 speed ALH TDI
05-09-2009, 02:58 PM
#25 (permalink)
Originally Posted by dremd
The cheapest I can find that gauge in the UK is $85 and Amazon.com refuses to send it to the UK for some strange reason.
05-09-2009, 03:01 PM
#26 (permalink)
6 speed Diesel FTW!
I was just coming to the same conclusion myself.
PM sent.
6 speed ALH TDI
The Following User Says Thank You to dremd For This Useful Post:
11-06-2009, 06:15 PM
#27 (permalink)
Cheap EGT stuff
I was looking at this a while back...
Aircraft stuff looks like it might work... ConAir Sports Ltd
Not bought one myself though (yet).
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
11-09-2009, 12:43 PM
#28 (permalink)
Thanks!
Already got one thanks to dremd - was mighty kind of him to send it to me. Unfortunately not installed it yet! Hopefully next week as I got a week off work.
11-14-2009, 03:26 PM
#29 (permalink)
Cartegena Uno Champ
Hi,
Just a thought have you considered a TUnit or something similar ? - I think they match an eco4 engine (CR Diesel ?).
They are normally associated with more power but at "min" setting they may give you an economy edge. You may also find a higher power setting results in more economy with different driving techniques especially in the UK with our absence of long, straight highways.
2011 Toyota Aygo Go!
Disclaimer - Postings from this author may be total rubbish. All figures in Imperial MPG unless specified. Use at own risk. Shake before opening. Store in cool, dry place.
Originally Posted by Gabriel Voisin about FWD
The system has the following merits: 1) It makes it easier to lower the centre of gravity and bring it forward. 2) It will free us from that unbelievable stupidity:a transmission shaft and tunnel between the engine in front of the driver and the driven wheels. 3) Front wheel drive will increase the interior space of the body, reduce the car's weight and diminish the cost price 4)It will annoy 320Touring by just being better  .
How to post images in Ecomodder.
11-15-2009, 01:52 PM
#30 (permalink)
Do you mean this? I've already considered it, £450 seems like an awful lot for possible fuel savings that isn't possible to calculate until it's installed, also my car's 8 years old with 85,000 miles on the clock, I don't think I'll make the money back in fuel savings.
BTW my engine doesn't have common rail injection - just the bog standard direct injection. Opel/Vauxhall didn't use common rail injection on their diesels until 2004, well after everyone else have changed over. However, there is a tunit available for my car anyway.
Originally Posted by carrythomas
Wow awesome post! I've learnt a lot - thanks! I'm not looking to touch the engine really, I'm happy with it. I'm just wondering whether an EGT gauge is worth it ...<snip>
I'm just being curious but why did you copy my post from a few months back...?
