View Poll Results: IS this to extream
Yes, your one crazy person 23 85.19%
no, looks great 4 14.81%
Multiple Choice Poll. Voters: 27. You may not vote on this poll
Old 05-30-2008, 03:17 AM   #11 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Looks like a kit car, I dig it! just dont go into steep driveways
Old 05-30-2008, 05:21 AM   #12 (permalink)
Certified Freak
Greenblazer's Avatar
Greenblazer's Taco - '07 Toyota Tacoma PreRunner Double Cab SR5 V6 4.0Liter
90 day: 24.54 mpg (US)
I am not an aerodynamic expert, but I agree that your tail is too long, and not sharp enough. The flat part in the rear is bad from an aerodynamic standpoint. I would suggest you follow the stock hatch line and curve the bottom up to meet it in a sharper point. Take a look at the Aptera's tail for some inspiration.
Later,
Allan Greenblazer
Old 05-30-2008, 06:25 AM   #13 (permalink)
Fortuga - '03 Subaru Forester X
90 day: 21.68 mpg (US)
The Beater - '94 Nissan Sentra EX
90 day: 28.88 mpg (US)
I trimmed your nose, rear and back roof (no more tall passengers) to what I believe to be a more reasonable shape that will still give you the benefit while allowing you to park better. I think it is more practical this way, even though you may not be squeezing every last drop of FE out of it.
Old 05-30-2008, 09:07 AM   #14 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I think that tail ^ is a bit short / steep. You might get flow separation somewhere along the way. I'd go with something in between the two.
Old 05-30-2008, 10:00 AM   #15 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
Yeah its the steepness of the tail that makes it so long.. the design I came up with was discussed by Areohead and Bajoos and I.. the profile i have there matches his profile but is extended to lessen the wake at the flat tail... less flat tail = less for a wake to form
Old 05-30-2008, 10:08 AM   #16 (permalink)
Veggiedynamics
practicality isn't a major concern, the nose thats already built as shown and on the car has not given me any problems with parking or entering driveways ect.
My main goal is if I'm going to go through the effort to make a tail it might as well be the best I can make... no compromises.
Old 05-30-2008, 10:28 AM   #17 (permalink)
ttoyoda's Avatar
In that case copy the tail of the m-111 record car. Put casters under it. They probably had *some* idea what they were doing, and they did not cut corners to save money, they made this car for prestige.
Just be aware the car may tend to turn into crosswinds on the road.
Old 05-30-2008, 10:30 AM   #18 (permalink)
Veggiedynamics
Later,
Allan Greenblazer
The stock hatch line is to fast (steep) the air seperates from it.. no sence in making any tail for it then.. I would gain nothing
Old 05-30-2008, 10:33 AM   #19 (permalink)
Veggiedynamics
yeah.. that may be bad.... I however am not running at 100+ mph like the 111.. no need for a shark fin on the back..
Old 05-30-2008, 10:58 AM   #20 (permalink)
ttoyoda's Avatar
For computational fluid dynamics modeling :
http://www.fluent.com/solutions/automotive/aero.htm
Big money unless you get it free at school. Not the eaisest to learn. Pitfalls for the unskeptical, i.e. you make an error in setting up the model or test conditions (true for any modeling software) you might get wrong answers and not realize it. I used to use it years ago, to model air flow thru heat sinks and air distribution ducts, and it was easy to spend weeks making models, running the simulation, interpreting the results. In the end, the PCB layout guys put components where THEY wanted, and we would make ducts and heatsinks so the product would not catch fire.
If you have no training in modeling with it, it will take you less time and you will have more fun just making the real thing. If you have the software free and someone can show you how to use it, then make models.
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1499 12-22-2019 07:24 PM
Gravity racer gallery - extreme aerodynamics trebuchet03 Aerodynamics 37 12-14-2010 05:04 PM
Extreme Vibe experiment trikkonceptz EcoModding Central 4 05-20-2008 11:50 PM
Extreme Idea 'IMA' for almost any car? landspeed EcoModding Central 6 04-03-2008 01:56 AM
AFS Trinity EXTREME Hybrids!!! cfg83 General Efficiency Discussion 10 01-18-2008 07:15 PM
