Old 05-28-2011, 10:29 PM   #21 (permalink)
BigWhiteWhale - '01 F250 Lariat Crew Cab Superduty
"wind tunnell" testing
The Following User Says Thank You to Bajascoob For This Useful Post:
Gtaw (06-04-2011)
Old 05-28-2011, 11:25 PM   #22 (permalink)
I like the video, looks like it will work very well.
Old 03-08-2012, 07:03 PM   #23 (permalink)
I have the exact same cab configuration as you and I was wondering if you had some closer/larger shots of it installed and how its mounted? How much total was all of that conduit? I have contractor pricing on homebuilding materials but I've never purchased it before. Would you be interesting in building one and sending it to me in parts?
Old 03-10-2012, 10:32 AM   #24 (permalink)
1/2 " EMT is pretty cheap. Even if I cut it up a little, it would be a long box I wonder If I just built the "intersections" then a person could cut straight pieces to match their bed size? I guess the only angle that would change would be the down bar to top of tailgate, and I could make that adjustable.
Old 03-10-2012, 11:20 AM   #25 (permalink)
right now the EMT is 1.69 at Lowes. Takes 7 "sticks" to make this so..$11.83
Old 03-10-2012, 06:02 PM   #26 (permalink)
Old 03-11-2012, 01:48 PM   #27 (permalink)
I should have done some research, this stuff is cheap, haha so even if I mess up it wouldn't be an expensive mistake. Thanks for the heads up, for some reason I had figured it would be much more expensive. Do you happen to have any larger close up pics? Mostly of the crossmember and where/how they tie in? This is of course unless you want to remain unique with your design! Haha thanks a lot for the information again.
Old 03-11-2012, 02:45 PM   #28 (permalink)
Gealii's Avatar
Shortster - '00 intrigue GL
90 day: 20.67 mpg (US)
ZX2 - '99 Escort ZX2 HOT
Team ZX2
Nice definitely headed this direction when i get around to the s10 eco build
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Idea for government: Traffic Light Timers newtonsfirstlaw General Efficiency Discussion 29 03-10-2012 11:33 AM
Technique quandary: gliding toward a stale green light - to pulse or not to pulse? MetroMPG Hypermiling / EcoDriver's Ed 27 04-15-2010 12:41 AM
4th brake light and Rear fog light. Sean T. Off-Topic Tech 10 11-27-2008 12:29 AM
