"You don't fail until you give up. You learn, and move on." - Christ " Hypermiling is not going slow, it's driving with more intelligence." - UFO Last edited by Cd; 04-07-2012 at 08:52 AM.. |
#28 (permalink) |
Ultimate Fail
BTW, That commercial is such a joke, the smoke is so fake.
Haha just look at the 'FrankLee' pressure bubble at the base of the windshield ...and that angle on the back ... great stuff.
"You don't fail until you give up. You learn, and move on." - Christ " Hypermiling is not going slow, it's driving with more intelligence." - UFO |
#29 (permalink) | ||
It helps rigidity, it's probably easier and lighter to make out of a flat sheet - sharp angles also concentrate stress when thermoforming plastics. A circle keeps the same aspect from every angle. Flow underneath the car isn't lengthwise, and the angle will vary with speed. Ridges will interfere with the actual flow pattern. Quote:
