Old 08-26-2010, 08:15 AM   #1 (permalink)
fan/grille controller
I plan on building a louvered grille block with 2 actuated zones and installing an electric fan in my tundra.
I wonder if i should use the extra pins on the obduino i'm building to control it. Also i wonder if i should use a temp probe through the radiator or the obd coolant temperature reading.
My plan is for 4 increasing temperatures to, open the upper grille area, open the lower grille area, turn the fan on low, turn the fan on high.
I bought a used variable speed fan controller that has a temp probe and turns the fan on 60% at the set temp and ramps smoothly up to 100% over +10deg. Now I'm wondering if I should ditch that and use relays and control the fan with the grille controller. The used fan i bought has 3 pins for a high speed and a low speed so variable speed is nice but not necessary.
Old 08-26-2010, 10:35 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I like the idea, but I think its overly complex. Why not just have one grill opening? Open it up a bit before the fan turns on, close it when it approaches the thermostat temperature.
I'm also not sure there is much advantage of going with a variable speed fan. I know fans are more efficient at lower speeds, but if your actuated block works properly, fan use will be very limited.
Old 08-26-2010, 01:43 PM   #3 (permalink)
The used fan which i already bought is 2 speed (3 wire). I bought a variable speed fan controller which PWM any fan slower. I bought it used I could have just as easily bought a 2 speed controller if that was available instead. I've never heard verified numbers for this fan but I believe its 35A high and 25A low.
Theres going to be three sets of louvers, top and bottom upper grille and lower grille slot. I could connect the sets mechanically but i could also actuate two of sections separately from the other.
edit: I didnt yet think about using the grille block controller or the obdguino and relays back when i bought the fan controller.
Old 08-26-2010, 01:59 PM   #4 (permalink)
I would leave the chrome plastic and cut out the black plastic. A set of short vertical louver s in the top and bottom upper grille and either one big or maybe a split in the middle horizontal louvers in the bottom. The upper grille curves more than it looks in that photo so horizontal louvers wouldnt work good on the top slots.
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 5824 Today 04:25 PM
Hybrid PWM/Contactor controller turbo-boost bennelson Fossil Fuel Free 24 05-12-2011 10:26 AM
Hondo's new controller Hondo Open ReVolt: open source DC motor controller 12 08-03-2010 09:59 AM
Ben's "Cougar" ReVolt Controller bennelson Open ReVolt: open source DC motor controller 35 05-28-2010 01:23 PM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 03:16 PM
