Old 02-26-2010, 02:30 PM   #1 (permalink)
Fancy helicopter blade tech, any terrestrial applications?
The Blade That Would Make Helicopters Almost Silent - Blue blade - Gizmodo
hmm... piezo-operated flaps on your deck lid? I'm not educated enough to tackle that one, but it's cool aero tech.
2002 WJ Overland E85/gas flex
2002 Motobecane 700DS
1978 ChevroLegs
Old 02-27-2010, 12:58 PM   #2 (permalink)
no-go?
I think that in automotive applications,this would be a solution waiting on a problem.
No properly designed auto would generate the type of vorticity this tech would suppress.
Tip velocities of a large rotor can approach sonic speeds with compressible effects which interact with incompressible effects occuring closer to the the rotor blade root, with velocities only fractional in comparison.
The tip also experiences spanwise bleeding as the pressure differential between the top and bottom of the aerofoil causes air to seek the lower pressure created by lift and momentum.Again,a properly designed auto aft-body can solve this problem.
The technology is cool,it looks like an outgrowth of the Q-Tip propeller which I believe originated in a classified US Army single-place aircraft used in Vietnam in the 1970s which could fly overhead at 100-feet,undetected.
