Old 11-29-2017, 12:04 PM   #11 (permalink)
V8 guy
I ran 75% antifreeze mix in my suburban once, took me a while to figure out why it was running hot. Once I dumped out some of the antifreeze and replaced it with water it was back to normal.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
Daox (11-29-2017), teoman (11-29-2017)
Old 11-29-2017, 03:18 PM   #12 (permalink)
Was that a nice and hot or a too hot scenario.
Old 11-29-2017, 05:12 PM   #13 (permalink)
V8 guy
Hitting 230F on a warm day not towing anything is bad.
Xist (11-29-2017)
Old 11-29-2017, 06:13 PM   #14 (permalink)
Ecomuggler
90 day: 35.55 mpg (US)
90 day: 34.24 mpg (US)
Were you driving vertically? Attempting to escape Federales? Please tell us how you achieved this feat!
Old 11-29-2017, 06:50 PM   #15 (permalink)
Added to the list! Those are good. Like any modification you must be aware of its consequences and thus check your oil more regularly.
I don't think that you will reduce your warm up time much, if any, by using a higher concentration of antifreeze, but you WILL reduce heat transfer quite significantly, meaning that the cooling fan will have to run more and you will have to have larger cooling openings. Detonation will also be more likely with reduced heat transfer because hot spots can develop. Glycol is also much thicker than water, so your water pump will take a lot more energy to spin, further offsetting any gains from faster warmup. If your goal is to reduce heat transfer, why not use 100% Propylene glycol antifreeze, aka Prestone Lowtox or something like it? Straight PG won't freeze unlike EG and doesn't transfer heat as well as EG based coolant.
Old 11-29-2017, 06:52 PM   #16 (permalink)
10) Concentrate the coolant to approx. 75% glycol
I don't think that you will reduce your warm up time much, if at all, by using a higher concentration of antifreeze, but you WILL reduce heat transfer quite significantly, meaning that the cooling fan will have to run more and you will have to have larger cooling openings. Detonation will also be more likely with reduced heat transfer because hot spots can develop. Glycol is also much thicker than water, so your water pump will take a lot more energy to spin, further offsetting any gains from faster warmup. If your goal is to reduce heat transfer, why not use 100% Propylene glycol antifreeze, aka Prestone Lowtox or something like it? Straight PG won't freeze unlike EG and doesn't transfer heat as well as EG based coolant.
Old 11-29-2017, 07:24 PM   #17 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Send a message via MSN to jakobnev
Just for the record: I had my glycol at 75%, full grill block, and my engine covered in bubble wrap, and it never over heated.
I guess YMMV.
Old 12-03-2017, 02:58 PM   #18 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
Last 3: 24.65 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 24 AUTO
Pickups
90 day: 22.62 mpg (US)
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
Automotive antifreeze viscosity table and viscosity chart
Dot know if this si for EG or PG
If you want to run strate then run E
ID:	23104  Click image for larger version
ID:	23105  Click image for larger version
1st gen cummins 91.5 dodge d250 ,16cm turbo housing ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 29.3mpg 97mi 3.311usg 7/27/16
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Xist (12-04-2017)
Old 12-03-2017, 03:56 PM   #19 (permalink)
Stubby79's Avatar
Topoff (RIP) - '92 Geo Metro LSi
90 day: 48.54 mpg (US)
'91 Miata - '91 Mazda Miata
90 day: 27.11 mpg (US)
'86 Fiero GT - '86 Pontiac Fiero GT
Purple Penny Pincher - '95 Pontiac Firefly Base
90 day: 43.68 mpg (US)
Jett-Black - '01 Volkswagen Jetta
90 day: 39.32 mpg (US)
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Straight antifreeze will freeze at -15c? Interesting.
I wonder how much higher the boiling point is when considering the additional pressure in the system (regulated by the rad cap)...like the difference between boiling water at sea level and at 8000ft.
Old 12-03-2017, 09:57 PM   #20 (permalink)
V8 guy
Where I am at 4400ft the boiling point is 208F.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
