Old 09-19-2017, 05:13 PM   #51 (permalink)
2015 WRX - '15 Subaru WRX
90 day: 29.73 mpg (US)
FWIW, my 2015 Subaru WRX has an oil-to-coolant heat exchanger, and the oil temperature tends to lag the coolant temperature by 10 to 13 degrees C.
Edit: The heat exchanger will also increase the time it takes to get to full coolant temperature. Most modern cars have warmup-fuel enrichment tables based on coolant temperature that make the car run richer with lower coolant temperature (up to a warmish temperature of 50-60C usually). It shouldn't be a huge effect but it will somewhat mitigate the gains from warmer oil temperature.
Old 09-20-2017, 11:03 AM   #52 (permalink)
V8 guy
Well scratch that idea.
The header I am going to use on the high compression 8L is hitting on the oil filter and
So the next plan is a remote oil filter kit, but still plumb the oil through the HX.
I have a carburetor, it runs leaner till the engine warms up.
Old 09-22-2017, 02:57 PM   #53 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
Last 3: 24.65 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 24 AUTO
Pickups
90 day: 22.62 mpg (US)
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
Consider using a twin head w/bi-pass filter mount.
--- would a fule filter heater from a Cummins be applicable on oil system
1st gen cummins 91.5 dodge d250 ,16cm turbo housing ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 29.3mpg 97mi 3.311usg 7/27/16
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 09-22-2017, 06:50 PM   #54 (permalink)
V8 guy
A twin remote oil filter is on its way as of the 20th.
The oil system has so much flow and mass in the system that I don't think a fuel heater would do anything. The oil is going to go through that heat exchanger before it goes to the filters.
The coolant has the 240v 5,500w heater and the oil pan has that 120v 1,200w heater element that I will run at 250 to 500 watts.
Old 11-29-2017, 02:43 PM   #55 (permalink)
90 day: 39.62 mpg (US)
Daox's 04 Civic - '04 Honda Civic DX
90 day: 42.25 mpg (US)
Any update on the heating setup?
Current project: Heating the manual trans with engine coolant
Old 11-29-2017, 05:19 PM   #56 (permalink)
V8 guy
All the parts are in I to custom make a stainless steel single piece 1/2"mpt to 3/4"mpt 90 elbow adapter that stuck out far enough to clear the engine.
I also have not had time to work on it much.
Maybe this weekend I will get to hook everything up and prime the oil system.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
Daox (11-29-2017), Xist (11-29-2017)
Old 12-01-2017, 02:17 PM   #57 (permalink)
Eeyore - '04 Honda Civic Hybrid
Go Pod - '00 Honda Insight AC
The Tinyvan - '07 Honda Fit Sport
For adding an oil cooler/coolant heater, can't get much easier than this OEM part from a Honda Insight (2000-2003 only IIRC).
https://www.hondaautomotiveparts.com...-+OIL+STRAINER
Parts #10 and 11 on the diagram.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
