Old 05-13-2017, 05:46 PM   #21 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Are you goig to do a bench run ,with frozen oil to verify that the increased viscosity will not have an insulating effect?
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 05-13-2017, 06:03 PM   #22 (permalink)
The oil would have to be so cold it would need to be like honey or maybe even thicker. You would have to use real thick oil when it's really cold out to have to worry about that.
Old 05-14-2017, 12:54 AM   #23 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
Viscosity of 15w40 6400 cP @Temperature -4.00 °F
ChevronTexaco RPM® SAE 15W-40 Heavy Duty Motor Oil
Viscosity of honey. aproxamitly 1800cP @ + 40°f
I do see -40°f in Montana. seen sub 0 in CA, OR, NV, WA ID,AND KS ,the many missing from list are those I have not lived in and had personal experience. Every state I have lived in so far this is a valid concern. At -4 oil is aproxamitly 4X thicker than honey kept in the fridge.
Former
87' Hyundai Excel
Old 05-14-2017, 11:36 AM   #24 (permalink)
About the only time I use 15w-40 is during the summer before a road trip.
Other wise I will run 5w-40 and I keep some 0w-20 to top off the oil when it gets real cold.
Old 10-25-2017, 09:55 PM   #25 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
My stock oil cooler wet the bed ... blew 2.5 ga of oil into the coolent. Ugg.. well got a chance to studdy the passages. Flow is : oil pump , heat exchanger , oil filter , turbo/block. Sence I've mesured at many different operating temps from 100°f - 185°f at all points the IR temp gun said oil and water are a dead match with the digital coolent temp gauge,however the block was considerably cooler then oil or water.
This is making me reconsider the probe placement(was going to put it in the filter head) of my planned dedacated oil temp gage.
Former
87' Hyundai Excel
The Following 2 Users Say Thank You to gumby79 For This Useful Post:
Daox (10-26-2017), slowmover (10-26-2017)
oil heater
