Old 04-30-2008, 09:30 AM   #1 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Fastening coroplast to the underbody
I ordered the coroplast for the Matrix last night and it should be in sometime today. So, I've been thinking about how I want to fasten it to the body. I don't want to squish it, but I need the bolts to stay in. So, I was thinking about using some bushings. How have you guys fastened coroplast to your body?
Old 04-30-2008, 02:35 PM   #2 (permalink)
Tinkerer
I'm looking at using push-ins where I need to mount Coroplast and have access to the other side. Some are acorn pushins and some look like a flat piece of metal stamped with a hole that will accept a screw but still keep some tension on it so it won't back out. You could just add a spring on a screw or mount a grommet on the coroplast and hang it with a spring. I'm still exploring ideas too.
Old 05-23-2008, 03:57 AM   #3 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
You can find or modify finishing washers to provide a flat flange around a countersunk screwhead. If you can't find any, drill and countersink a chunk of scrap, and then pound regular finishing washers.
Where did you buy Coroplast? tjts1 EcoModding Central 28 11-18-2009 02:12 AM
crx coroplast belly pan finished! paulwelkins EcoModding Central 25 06-13-2009 02:14 PM
Coroplast undertray question (covering the control arms) Otto Aerodynamics 8 03-30-2009 01:27 PM
Great find: partial underbody tray for Gen1 IS300 and Gen3 Camry NoCO2 Aerodynamics 3 04-22-2008 02:04 PM
Coroplast question Otto Aerodynamics 14 03-28-2008 12:45 AM
