Old 04-10-2009, 08:37 AM   #31 (permalink)
Weight Reduction
Drive Stick's Avatar
neon - '95 neon Highline
90 day: 37.7 mpg (US)
Subaru - '98 Legacy L Wagon
90 day: 29.94 mpg (US)
Saab - '98 900 S
90 day: 51.25 mpg (US)
Impreza 2.5i - '011 Impreza 2.5i
90 day: 24.06 mpg (US)
Blue Crush - '011 Prius II
90 day: 50.98 mpg (US)
Send a message via AIM to Drive Stick
I have started working on my prototype part which will cover the section of tire which the stock bumper does not. This was supposed to be a final piece but I wasn't cutting straight so it doesn't fit how ever I will be making more cardboard models until I get the edge contour perfect.
Once I have the desired exact dimensions, I will cut the plastic almost identical to what you see here, give the inner edge a 45° angle so it can flush mount to the bumper, and attach it in the back with 2 mounting locations, at least. The leading edge will be sealed with a rubber gasket I have left over from truck flares, or some RTV if I can't find the gasket.
Old 04-10-2009, 11:35 AM   #32 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Drive Stick -
Even so, that's really clean.
CarloSW2
American Solar Energy Society
Old 04-29-2009, 01:31 PM   #33 (permalink)
daqcivic's Avatar
Daq Civic - '92 Civic DX sedan
90 day: 42.54 mpg (US)
The Hardbody - '91 D21 (pickup)
That's very clean, and looks like it will improve airspeed across the front wheels. Have you finished yet? I was wondering how you planned to attach them.
Old 05-01-2009, 05:07 PM   #34 (permalink)
EcoModding Wannabe
Pug - '99 306 HDi DTurbo
Very nice - had you thought about dropping them slightly lower than the bumper like modern cars to reduce air getting to the wheel well?
That little lip has got to reduce the frontal area by 10ish%...
Old 05-02-2009, 08:12 PM   #35 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
While reading this thread I remembered the 84-86 Mustang SVO. It had flares or "spats" for the rear wheels I found these. A bit pricey to cut up to make fit another car in my opinion. So I submit these as a good (hopefully) point reference.
SVPU Store - 84-86 Mustang SVO reproduction side spats (Powered by CubeCart)
Cheap-o Smooth Wheel Covers bennelson Aerodynamics 40 03-15-2009 11:55 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
wheel covers: corugated plastic or taped hubcaps? modmonster Aerodynamics 4 02-08-2009 07:54 PM
Fender flares to make front wheel skirt jthistle Aerodynamics 13 09-12-2008 10:16 PM
Modded wheel covers to make them smooth MetroMPG Aerodynamics 1 11-27-2007 08:43 PM
