A few questions I need answered about 07 civic hybrid
How do I do a valve adjustment by myself?
Do I have to adjust the timing belt? If there is any? How can I do a DIY alignment? It really needs it. Winter mpg is rather bad, is this the sign of needing a new thermostat? What are the most comfortable tires in terms of handling road bumps and noise? I figure if I just get those and pump up the air more I should be fine for mpg. |
Make sure to check the clearance specifications for your specific engine. Quote:
I eyeballed my alignment after rebuilding the front end from when my ex wrecked my Insight, and it was fairly close, but I have a feeling you're likely still going to chew up your tires if you don't get it done professionally.
Winter mileage is bad for a lot of reasons. Get your car aligned, avoid short trips, invest in a block and oil pan heater, block your grille, and make a warm air intake. Even then, expect it to tank when the weather is cold, just less so. Edit: I think Michelin Energy Savers are nice tires, but they're definitely more economy focused than comfort. They last a long time and you might get 10-20% better fuel economy over non-LRR tires, but they're not going to be the most luxurious ride you've ever had. |
https://www.tirerack.com/tires/tires...d&autoModClar= https://www.tirerack.com/tires/tires...d&autoModClar= |
Hard to say regarding tire comparison. Nobody really does apples to apples comparisons of tires, especially where fuel economy is concerned. It's well documented that in the G1 Insight, it's typical to lose 15-20% economy by using most off the shelf non-LRR tires, whereas Energy Savers, Ensaves and the stock Potenza RE92's return pretty similar economy. The lost economy also shows up in performance, hurting acceleration, which to me is a lot of tradeoff.
I want to say it was MetroMPG on this forum that did some roll-down testing with various tires at various pressures, maybe they'll chime in. |
Manual or CVT Civic? |
I'm dipping down to nearly 58 this tank. I recently moved into the heart of Burlington and I have a lot of cold start short trips (<3 miles) that are 25-35mpg. On the highway I can see 80-90 in this weather, especially if it's long enough to get all of the fluids and tires warm, so my overall average is somewhere in the middle.
