Old 09-01-2008, 09:43 PM   #11 (permalink)
zx3zetec's Avatar
ZX3 Focus - '01 Focus ZX3
90 day: 31.47 mpg (US)
Thank you all for your opinions!
I think I will try a "Complete Fuel System Cleaner" from Valvoline.
I'm not expecting any miracles, it's more for prevention/routine maintainance.
Old 09-01-2008, 10:08 PM   #12 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Be sure to post in the "Off Topic Tech" forum when you need help replacing your fuel pump
Just kidding
or am I...............
Old 09-01-2008, 11:14 PM   #13 (permalink)
Whitey - '03 Cavalier base
90 day: 37.01 mpg (US)
i put some chevron techron in mine about every other to 3 oil changes. does it help? i dunno just do it because i've heard good things. it did seem to make an improvment in my moms explorer though, did it at about 70k miles for the first time, so maybe after so long it did really help. its supposed to clean out carbon desposits and such in the cylinder itself also.
also zetec, keep reading and learning here. i have been and its worked wonders. i know the zetec is a great motor for FE, as i had a duratec (2.3) for some time and i was able to squeeze around 35mpg out it, even before knowing some of what i do now. you'll be over 30 in no time
Old 09-03-2008, 11:36 AM   #14 (permalink)
OfficeLinebacker's Avatar
I find that the tank in which the FI cleaner is added gets lower mileage, and the mileage doesn't go up on subsequent tanks.
I prefer the TB cleaning technique where carb cleaner is sprayed directly down the TB and/or one or more vacuum lines are used to suck water/seafoam/whatever into the engine while running. Results are immediate and doesn't require sacrificing an entire tank of gas. One can also customize the cleaning, be sure to clean the PCV system, etc. The only thing it doesn't get is the inside of the injectors.
There's a really sophisticated method where a machine containing some BG product is hooked to the fuel line and the engine is run on this special cleaning mixture for several minutes. If that is worth the cost I'd like to know.
Old 09-03-2008, 02:08 PM   #15 (permalink)
ptsmith24's Avatar
El Camrino - '90 Camry LE
90 day: 32.47 mpg (US)
I can't clean the TB while my vehicle is running since I have to remove my entire intake (air flow sensor included). In other words, the motor thinks it isn't getting any air and thus doesn't inject any fuel. Maybe there's a way to do it properly, but I just start it up (after several tries, letting the starter rest when appropriate) after cleaning the TB.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Old 09-03-2008, 02:55 PM   #16 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
zx3zetec -
In the past I have used Redline fuel system cleaner for my Saturn, but I haven't noticed any performance or MPG change. I would like to try Sea Foam, but I have a hunch that my mechanic already uses it for me during tune-ups.
CarloSW2
American Solar Energy Society
Old 09-03-2008, 03:38 PM   #17 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Not too long after picking up my '93 Tercel I dumped a bottle of cleaner though it. At that point, the car had around 130,000 miles on it. The cleaner noticably smoothed idle and the engine reved smoother. Now, I use it here and there, maybe 1-3x a year.
Old 09-03-2008, 05:11 PM   #18 (permalink)
Use the PCV intake hose or just crack the joint between the intake hose and the TB. Failing that, try one of the smaller vacuum lines, and continue to just spray copious amounts of stuff down it's throat with the engine off (use a rag to catch the overflow). You'll see the brown gook it's washing out of the intake.
The above methods don't clean the injectors; similarly, fuel additives don't get the TB, EGR, or, most importantly, the IAC.
Last edited by OfficeLinebacker; 09-03-2008 at 05:11 PM.. Reason: I misspelled IAC
Old 09-03-2008, 06:12 PM   #19 (permalink)
ptsmith24's Avatar
Thanks for the suggestions. I usually just remove the entire intake (sensor and all) and spray down the actual throat of the TB while opening and closing the valve using the throttle control (under the hood). When I clean the TB, I usually add FI cleaner at the same time. I hope to surpass the 200k mile point before the end of this year. I am just under 196k right now.
Aero'd RV or worlds largest street cleaner pasadena_commut Aerodynamics 2 08-27-2008 04:37 PM
News: Under-inflated Tires Waste 5.3B Liters of Fuel/Year in Europe MetroMPG General Efficiency Discussion 3 03-06-2008 10:23 PM
