06-26-2015, 12:20 AM
Cyborg ECU
Film: 1950s Army planetary gear demonstration model
Learning about planetary gears by trying to visualize how they work, and I came across this neat old training film. Seems I'm not alone in needing animation to understand!
And here is a different and also excellent demonstration, using computer animation:
06-26-2015, 10:32 AM
In Lean Burn Mode
I Love this stuff!!!
It amazes me how much advancements were made and discovered in the early 40's through the late 50's.
I think planetary gears transmissions auto type transmission are just the perfect package. Compact and strong as Hell.
Pressure Gradient Force
The Positive Side of the Number Line
06-26-2015, 02:54 PM
I've never been a big fan of planetary gear sets. But it's possible that's because I associate them with automatic transmissions, which I strongly dislike...
-soD
06-26-2015, 04:08 PM
Cyborg ECU
-soD
Me too. Dislike. But my electric bike has a set in the hub motor, and I am trying to understand the mechanism to understand how to hack it.
06-26-2015, 07:00 PM
Yes, quite so...
Did you notice that explanation of the two-input planetary gearsets used in tanks? That's exactly how Toyota's groundbreaking Hybrid Synergy Drive works (specifically the "Power Split Device").
Toyota Prius - Power Split Device
The Following User Says Thank You to darcane For This Useful Post:
06-26-2015, 07:09 PM
-soD
Some of the most robust manual transmissions use planetary gearsets. In drag racing, Lenco transmissions are used on very high powered cars because conventional manuals won't handle the torque. The reason they can handle the torque are planetary gear sets.
06-26-2015, 08:33 PM
...beats walking...
This is "how" the differential-gearset (left) is related to the planetary-gearset (right, ala' Prius):
The Following 2 Users Say Thank You to gone-ot For This Useful Post:
06-26-2015, 08:41 PM
Cyborg ECU
That's a pretty cool detail. My "dislike" was only about the classic auto. CVTs attract me, a little. But I had no idea planetary gears were going into manual transmissions for drag racing. Here are a couple Lenco tranny images...
