Old 11-13-2009, 05:11 PM   #1 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Taurus GL (Sedan)
90 day: 18.61 mpg (US)
Finally an attractive front end grille bock!
Well I installed my front end grille block yesterday!
Can anybody see it?
No results yet, but in theory it seems like it will help!
Old 11-13-2009, 05:17 PM   #2 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Here's a better picture!
It's clear vinyl I ordered online, I just put it over the turn signal cavities and the upper grille. Any consensus on whether you think it will be helpful or not?
Already tested the temperatures (it was real warm yesterday) and it hasn't effected them at all.
Old 11-13-2009, 05:19 PM   #3 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...a genuine "stealth" air-block for sure.
...sheer ingenuity!
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 11-13-2009, 09:17 PM   #4 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
Nice, very clever. I assume it;s the same material that is used for protection from chips on the paint?
It was the rage several years ago. The edges tend to get dirty from the residual glue. Also it tends "weather" get's a darker shade. also it is IMPOSSIBLE to remove after 6-8 months.
But you achieved what is the fundemental concept of blocking. THe air never knows there is a block. perfect flow with the existing body lines
And you picked up the most qualitative aspect.....nobody can tell!!!
ADDED: here are my side mirrors today. I had bought the whole deal (entire front bumper) to protect against nicks) it was a pain to install so I did the side mirrors only. It's been 2 years and you can see my efforts to 'peel" it off!!
Old 11-14-2009, 12:29 AM   #5 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Hrm.... I don't mind the discoloring... but what's this IMPOSSIBLE to remove you speak of...???
I'm a little worried now.
Old 11-14-2009, 03:05 AM   #6 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
The glue on them "sets up" hard as nails, and the plastic gets brittle with age. It makes it fairly difficult to remove the pieces after extended exposure.
I'd probably peel it after testing if there isn't a defined effect from it. If there is, I'd most likely still peel it and see about making a foam plug for the upper grille block and maybe either moving the turn lenses forward in the bumper cover, or making a thin lexan cover or similar.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 11-14-2009, 03:32 AM   #7 (permalink)
Master of 140 hamsters
superchow's Avatar
Hamster - '07 Civic EX
90 day: 36.76 mpg (US)
Grampa Frank - '98 Forester L
90 day: 29.49 mpg (US)
First thought: Cool!
Second thought: Audi A1 Sportback Concept
Your're aparently not the first with the idea of a invisible grille block. Looks great though. Keep us posted on how it keeps up in terms of getting dirty from the sticky back side.
Old 11-14-2009, 05:31 PM   #8 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
I've had vinyl windshield banners before and they weren't too difficult to take off... hmm, maybe I'll try putting a scrap of vinyl lower on the bumper as a test piece. That way I won't have to fiddle with the grille block.
Old 11-14-2009, 06:12 PM   #9 (permalink)
Is it vinyl? Then you're most probably safe. I saw that it was clear and very thin, and assumed it was plastic with adhesive on it, and it would have made the previous poster's information a concern. Vinyl (that I've heard) doesn't do the same thing.
Old 11-14-2009, 06:36 PM   #10 (permalink)
saturn - '99 sc1
90 day: 35.67 mpg (US)
thought about doing anything to the back side of the vinyl? i was thinking the inside covering the grill opening would slowly get covered with dust dirt and bugs if its sticky. as would the turn signals at a much slower rate
front end mod questions puddleglum Aerodynamics 0 10-18-2009 11:34 PM
Grille Blocking Front or Rear trikkonceptz Aerodynamics 11 08-04-2008 12:45 PM
Honda Element 2 front end mods hans2vt Aerodynamics 5 07-29-2008 07:13 AM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 11:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 11:14 AM
