Originally Posted by JimL10
I tried to get a jump on improving the milage on my 04 Frontier extgended cab by adding a gadget called Mileage Monster Hydrogen system. Cost a little under $700 installed. The net effect after 1395 miles appears to be pretty much negative. My recommendation is that you not waste your money.
I also have a Scan Guage II. Its readings seem to change more rapidly than I can compensate. Does anyone have any ideas for smoothing that might eliminate the rapid changes? I also would like to hear any ideas for improving the bricklike design that I have to deal with.
Bugger on the hydrogen thing (we, or at least I, would have told you that before the installation :/)
As for the
SG, lower the refresh rate.... The instantaneous fuel consumption changes in real time. So either set the
SG to report less frequently (it might average over the time period - and thus smooth out) or program the driver to smooth out the numbers in his/her head
As for brick like design - of your car or of the SG?
