Old 04-01-2017, 08:43 AM   #381 (permalink)
I thought the GM hybrid used a motor built into the torque converter area of the drive line.
That would have made much more sense, no wonder Toyota/Hino resorts to that approach in their hybrid trucks. And the subsequent generation of full-size GM hybrid trucks and SUVs ended up resorting to that "two-mode" hybrid setup co-developed with Mercedes-Benz and Chrysler instead of the BAS-Hybrid.
The stupid belt driven motor idea I thought was only a car thing.
Even though it's been quite over-rated at the time, I honestly believe a similar BAS-Hybrid setup is not so unlikely to become mainstream in the next 10 or 15 years at least in the cheaper penalty-boxes.
Old 04-02-2017, 06:11 PM   #382 (permalink)
Bill the Engineer's Avatar
Mischief managed. The project is funded for another year.
Bill the Engineer
The Following 4 Users Say Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020), Daox (04-03-2017), mcrews (04-15-2017), slowmover (04-02-2017)
Old 04-05-2017, 07:18 PM   #383 (permalink)
Here is a rough guess at the difference between what a stock 1967 Firebird looks like and the finished Firebrid.
Most people will never notice.
3 more days until Garage Opening Weekend!
Bill the Engineer
The Following 5 Users Say Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020), ECO-AKJ (04-06-2017), LittleBlackDuck (04-06-2017), mcrews (04-15-2017), me and my metro (04-05-2017)
Old 04-06-2017, 07:21 PM   #384 (permalink)
Toyota Prius v Superdown Sus Springs 2011+ | RS-R USA
RS-R T088S Super Down Sus Lowering Spring Set
Ordered a set for the Firebrid this weekend from a different website that still has some. They should improve both the ride height and handling.
Bill the Engineer
The Following 2 Users Say Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020), ECO-AKJ (04-07-2017)
Old 04-08-2017, 04:08 PM   #385 (permalink)
Welcome Spring! So then, let's pick up where we left off last Fall...
Bill the Engineer
The Following 6 Users Say Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020), Daox (04-15-2017), eco_generator (04-08-2017), mcrews (04-15-2017), me and my metro (04-08-2017), nemo (04-08-2017)
Old 04-09-2017, 07:24 PM   #386 (permalink)
Great day in the garage. It's been too long since I've had some wrench therapy.
Bumper, core support and mounting brackets are back off of the car.
The cut-off wheel made quick work of the bracket pieces that needed to be cut apart. I also got some of the cuts made on the core support before the garage time was over.
Three day weekend for me next weekend. I should be able to start welding the brackets into their new configuration by then.
Bill the Engineer
aerohead (06-19-2020), ECO-AKJ (04-10-2017), RedDevil (04-10-2017), roflwaffle (04-11-2017)
Old 04-12-2017, 05:24 PM   #387 (permalink)
The RS-R Super Down Springs arrived today!
Bill the Engineer
The Following 3 Users Say Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020), eco_generator (04-14-2017), mcrews (04-15-2017)
Old 04-12-2017, 05:47 PM   #388 (permalink)
Focused on MPG
Marinator - '06 Mercury Mariner Premier
90 day: 10.61 mpg (US)
SILVER BULLET - '19 DODGE GRAND CARAVAN GT
90 day: 18.41 mpg (US)
Myrtle - Wife's JKU - '12 Jeep JK Unlimited Sport
90 day: 15.7 mpg (US)
Woohoo!!!
Staying Focus'd on MPG
The Following User Says Thank You to ECO-AKJ For This Useful Post:
Bill the Engineer (04-13-2017)
Old 04-14-2017, 06:43 PM   #389 (permalink)
Day off from work for Good Friday holiday. I'm glad it was sunny and in the low 70's degF. Got a decent amount done in the afternoon.
Front bumper bracket parts filed, drilled and fitted to be welded tomorrow.
Initial cut-out of the old Firebird radiator support got to the point I could hang it on the car over the radiator. I need to make adjustments here and there once the front bumper is back on.
Bill the Engineer
aerohead (06-19-2020), Daox (04-15-2017), mcrews (04-15-2017)
Old 04-15-2017, 09:13 PM   #390 (permalink)
Another good day in the garage. I welded the front bumper brackets into their new configuration and ground down the rough spots. I then mounted the brackets onto the front of the car.
Then I mounted the front bumper assembly back onto the front of the car. So far so good.
The new configuration is going to look much nicer, having chopped 6 inches out of the extra length. It is only 4.5 inches longer than stock now, and things are positioned nicely for the fender supports.
A very satisfying day!
Bill the Engineer
aerohead (06-19-2020), RedDevil (04-16-2017), Saskwatchian (04-15-2017)
convertible, firebird, firebrid, hybrid
