05-13-2009, 11:18 AM
#41 (permalink)
" CAFE " Dual-fuel vehicles, such as E85 capable models, are taken as the average of this alternative fuel rating and its gasoline rate. Thus a dual-fuel E85 capable vehicle which gets 15 mpg on E-85 and 25 mpg on gasoline would be rated as 20 mpg for CAFE purposes, in spite of the fact that less than one percent of the fuel used in E85 capable vehicles is actually E85.
" CAFE standards is not 100 + mpg for E 85 cars "
I will say high mpg with 400 hp in a V8 engine truck is not what you're looking for when you're pulling the camper or boat down the road 5 to 6 hundred miles on vacation.
" I guess you're right a electric 2 seater 3 wheeler is better."
Reason: Data
05-13-2009, 12:08 PM
#42 (permalink)
Slow and easy
Josie - '87 Pickup 90 day: 30 mpg (US)
Putting your voodoo math to the side, how many miles does your vehicle get per BTU in the tank? Is that significantly better than an unmodified Mustang? Comparing BTUs on the flexfuel Mustang to BTUs on a stocker from some McDonald's parking lot, apples to apples.
Don't start parcing out content percentages, just come straight out and tell us: on a fillup of X gallons of liquid fuel, how many miles? Just declare without any qualifications, a full tank of (fuel) yields _______miles.
I'm assuming that if I were to take your car, put in 3 gallons of 100% gasoline, it would not go 300 miles. I also don't believe that it would cover the same 300 miles on E85. Can you refute these assumptions without turning to your obfuscatory math and qualifying statements?
You're not in front of me...
I'm 25,000 miles in front of you.
05-13-2009, 12:29 PM
#43 (permalink)
Dartmouth 2010
Is spamming this site really how you plan to market your car?
05-13-2009, 01:07 PM
#44 (permalink)
Mechanical Engineer
I must admit I was hoping that the hp2g Mustang might have proven to have had more up its sleeve that first appeared. "Cautiously optimistic" you could say. The more skeptical engineering side of me finally took over and I calculated it out.
Everyone's right; his 110 mpg is pure BS using only the gasoline portion of the gallon of E85 to calculate mileage. Hence the apparent failure to satisfy the X-prize requirements.
I double-checked my calculations: using 25.2 MJ/L as the energy value of E85 and the published data of Cd 0.42, A=22 ft^2, and mass 3250 lb published on the hp2g website, comping him an optimistic Crr of .006 for tires the best he could hope for (i.e. efficiency=100%) to overcome rolling and aerodynamic friction at a steady 55 mph is 149 mpg.
To achieve 110mpg at a steady 55mph he would have to exceed 84% thermal efficiency (including motor friction, drive line friction, and combustion efficiency). This is simply not possible. The maximum theoretical Otto cycle efficiency is only 64% for a very high compression ratio of 14:1. An efficient drive line would knock at least another 10% off.
hp2g: I'm glad you've already brought lawyers on board with your "team." I hope they're smart enough to straighten out your claims before you sell a product to someone. I'm sure the FTC will be watching.
05-13-2009, 01:26 PM
#45 (permalink)
I must say Thank You for following the HP2g engine progress.
Attorneys are needed to protect the Intellectual Property ( Patents ). I do have some of the best attorneys in the U.S.A.
Reason: data
05-13-2009, 01:40 PM
#46 (permalink)
LurkoModding Ecker
I applaud you for creating an E85 capable engine, that is a wonderful thing you are doing for the environment. And I am glad that someone who is doing something good for the environment has some of the best attorneys in the U.S.A. because with your incredibly false claims you will need those lawyers to defend you in the ensuing class action law suit filed by the people who paid hard earned money for a 110 mpg vehicle that actually gets 16.5 mpg. But keep up the good work.
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong. -Buckminster Fuller
05-13-2009, 01:52 PM
#47 (permalink)
IP ( Intellectual Property ) attorneys are for IP only.
I wonder if Edison got the same response back when he invented the light bulb or the phonograph?
05-13-2009, 02:14 PM
#48 (permalink)
EcoModder Student
He would have if he claimed the light bulb could play music and the phonograph could light up the room..........but HE didn't.
P.S Does your engine run on snake oil?
Eric
05-13-2009, 02:43 PM
#49 (permalink)
Dartmouth 2010
Since we have clearly established the claims as deceptive and their numbers complete BS, I feel like we can close the thread.
I will also be deleting their garage entry as it does not represent actual fuel consumed.
