Old 06-29-2011, 10:15 PM   #1 (permalink)
60+ mpg at posted speeds
California98Civic's Avatar
Black and Green - '98 Civic DX Coupe
90 day: 64.83 mpg (US)
First 60+ MPG tank
Improved "driving with load" technique (thanks PaleMelanesian) and my modest ignition timing were the only new mods. This was the first full tank under this new regimen.
Black and Green will be rebuilt over decades as parts die--until it becomes a different car. Goal is only 60-70 mpg at posted speeds. I'm not trying for highest possible mileage.
Calculators: standard deviation, Ohms Law, & drag HP losses.
Old 06-29-2011, 10:30 PM   #2 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
Congratulations! That's excellent fuel economy by any standard.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
Old 06-30-2011, 06:50 AM   #3 (permalink)
piers.singer's Avatar
Very well done, sir! Keep up the good work.
Spoken like a champion. Oh no, disaster!
Old 06-30-2011, 09:59 AM   #4 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Very nice. Think you'll hit 70?
Old 06-30-2011, 10:16 AM   #5 (permalink)
99metro's Avatar
putt-putt - '99 Metro Base
90 day: 58.76 mpg (US)
Dusty - '89 Bronco XLT
90 day: 13.89 mpg (US)
Cowboy - '90 Bronco XLT
90 day: 17.42 mpg (US)
HayHauler - '06 3500 ST
90 day: 18.03 mpg (US)
60 mpg+ is VERY nice for those big honkin' motors you guys run in those Civics!
2006 3500 Dodge QC/FB 5.9 handshaker
Old 06-30-2011, 12:05 PM   #6 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Welcome to Diesel Territory
Lifetime fuel consumption :
Old 06-30-2011, 12:15 PM   #7 (permalink)
I'll have to wait and see. I drive a lot of hills, so 60mpg was tough. I'm thinking I might be able to get even more out of DWL technique. I wonder if I can go to 85% load without going into open loop if I keep the timing advance reading at 8 or higher. Does that make any sense technically? Can I use the timing advance, load, and RPM gauges to more precisely identify where open loop kicks in? I think maybe increasing timing advance complements the DWL strategy because the extra advance keeps the timing further into positive territory at low-speed 1300-1500 rpm acceleration. But I'm not much of a mechanic. What do you guys think?
I'm also ready and supplied to do a few more mods and grab a few ounces back from the goblins: reduce the idle speed 8-10%, advance the ignition timing 2 more degrees (total 16 BTDC instead of stock 12), and an airdam. Then there are some maintenance ideas: high flow air filter (old is getting dirty), clean wiring connections to battery and ground a la MetroMPG. Lots to do!
Old 06-30-2011, 12:28 PM   #8 (permalink)
CM400E - '81 CM400E
I wouldn't worry about open loop as much as your timing backing off on you. Before you see open loop, the engine will start retarding the timing to avoid knocking.
