Old 05-15-2011, 04:29 PM   #1 (permalink)
Dodge Neon - '04 Neon SE
90 day: 39.86 mpg (US)
First Attempt at some aeromods-Dodge Neon
First of all, sorry for the long post.
I have been reading about covering up some of the grill to improve aerodynamics. Since I have pretty consistent mileage numbers, I thought I would try this to see what effect it will have on my MPG. But I have a question, what temperature should I try to keep under on my radiator? From my scangage, I know my Neon stays pretty steady at 192F. But what would be too high? The coolant gauge on the IP is nothing more than an idiot light since it doesn't move when the water temp runs from 180-210. The reason I ask is that I did my first mod and think I covered too much. The temperature got as high as 210 (during some running around town). I came back home and opened up some more grill and went for another test run. Now it seems to be staying under 205 (193-204). This is on a relatively cool day - 70F.
I must say, my regular commute (50 miles one way) is 90% highway (60-70 MPH), so I am thinking this shouldn't be an issue at that speed. But on the weekends running around town I don't want to have to worry about it getting too hot. Thanks for the read
Old 05-15-2011, 04:30 PM   #2 (permalink)
First attempt pictures. I had some scrap lexan laying around. I thought I would try a temporary fix until I see what kind of improvements I have AND how much grill needs to be exposed.
Old 05-15-2011, 04:31 PM   #3 (permalink)
Second attempt, I should point out that on the Neon I have, the lower part of the honeycomb grill is actually blocked off from the factory.
Old 05-15-2011, 06:53 PM   #4 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle - '01 Echo Sedan
90 day: 42.53 mpg (US)
Looking good so far.
On my car, the coolant temperature hovers around 184F-188F while cruising on the highway and gets up to 204F in heavy traffic. The electric cooling fan turns on at 204F. Took me several trial and error grille blocks to prevent as much as possible the fan from turning on.
I personally don't like when the coolant temp is above 210F. It is too high IMO. Besides, Summer is around the corner and must be taken into consideration when installing a grille block.
The Following User Says Thank You to CigaR007 For This Useful Post:
HannahWCU (05-15-2011)
Old 05-15-2011, 07:34 PM   #5 (permalink)
Thanks for the info! I feel the same way about the 210. When I saw that on my scangage, I was like . But I think I will leave it the way it is and keep the Water Temp on the scangage and see where it goes. I think, at least for my commute, it will stay below 210F.
I also want to try to keep the fan from coming on. I dont want the additional load on the engine (I dont even run the fan on the HVAC to reduce the load).
Old 05-15-2011, 07:52 PM   #6 (permalink)
CigaR007's Avatar
Definitely keep track of the temperatures on your scangauge. You will then know what works best for your car in terms of grille blocking.
Experimenting is fun !
Old 05-15-2011, 07:58 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
HannahWCU -
I like it! Very stealthy.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
HannahWCU (05-16-2011)
Old 05-15-2011, 11:36 PM   #8 (permalink)
Black Knight - '94 Corolla
90 day: 61.92 mpg (US)
200 or below is fine and put that grill block in the front for better mpg.
Old 05-16-2011, 08:52 AM   #9 (permalink)
My thinking on leaving the center open was to maximize airflow to the radiator through the smallest opening possible. I could cover the middle (around the license plate holder) of the center and leave the sides, near the foglight openings clear. But it seems to me, that would reduce the cooling efficiency since the airflow would not have as direct route to the radiator. Am I looking at this wrong?
The center opening is the only one that goes directly to the radiator. Also, the passenger side opening (where a foglight would be in some models) actually goes to nothing. The drivers side opening appears to go to the AC, but since I don't usually run the AC, this shouldn't be an issue.
Old 05-16-2011, 01:18 PM   #10 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
That's the way to go IMO.
You'll need some cooling anyway - especially when summer comes along.
You can always add some more blockage in winter.
Have you blocked the upper grilles as well ?
Any reasons to keep the plate on the front ?
It doesn't look like a licence plate.
Lifetime fuel consumption :
