Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 07-18-2017, 03:53 PM   #41 (permalink)
One might be able to replace the plastic gears with metal ones at some point. The NY Finger Lakes are beautiful too. In hilly country having the option of dynamic braking is worth considering.
Old 07-18-2017, 05:41 PM   #42 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Yes, the planetary gears inside these motors can be replaced/upgraded. Lyen makes a hardened steel sprocket for hub motors. 25 bucks each. We would need three.
LYEN Controllers
And here is a guy who experimented with installing them on his trike:
Ecky (07-18-2017)
Old 07-18-2017, 11:09 PM   #43 (permalink)
90 day: 40.51 mpg (US)
Finished build:
Pretty stealth! And, I was expecting the geared motor to be louder than it is. It's not entirely silent, but very close.
Total time of assembly was around 2 hours, mostly due to having to solder together a harness to connect my 3 batteries in parallel, and having to run to the local bike store after popping a tube because I forgot to move the rubber liner that covers the spoke holes in the rim, to the new rim.
Acceleration is pretty similar to a 50cc scooter, and top speed appears to be around 20mph. With a 115lb rider, it's entirely unnecessary to pedal even up the steepest hills.
This hub motor does indeed freewheel, and very well at that. There's virtually no drag.
I can probably get a smaller bag. The 13.2ah of batteries take up about this much space:
California98Civic (07-19-2017)
Old 07-19-2017, 11:00 AM   #44 (permalink)
Cyborg ECU
Real stealth!
Old 07-20-2017, 11:44 AM   #45 (permalink)
Thalmaturge
The Tinyvan - '07 Honda Fit Sport
I can probably get a smaller bag. The 13.2kWh of batteries take up about this much space:
Surely you must mean 13.2 ah of batteries?
I've got a 36V Bafang BBS02 and 8 ah of lithium and a 7-speed rear cassette... in 1st gear the acceleration is nuts, but it tops out around 13-14mph. In 7th, the acceleration is acceptable, but the motor's getting worked pretty hard. I usually do 4th or 5th for top speed (around 28 mph level ground no pedaling).
If I just use it for tough hill climbs, it's good for 50 miles If I don't pedal and just mash the throttle all the way, it'd probably only last about 8 miles.
The Following User Says Thank You to samwichse For This Useful Post:
Ecky (07-20-2017)
Old 07-20-2017, 12:01 PM   #46 (permalink)
Fixed! Was very tired when I typed that.
Old 07-20-2017, 02:24 PM   #47 (permalink)
Cyborg ECU
Instead of a smaller bag, make a separator to wall off the battery and use the residual space inside the bag for some storage.
Grant-53 (07-21-2017)
Old 07-21-2017, 10:43 AM   #48 (permalink)
If you are interested we can discuss aero drag reduction techniques.
Old 07-21-2017, 01:14 PM   #49 (permalink)
Yes please.
Here are a few things I've come across already:
Smooth wheel covers
Dopperugyanga 700C Black Bicycle Wheel cover DWC064-BK ABS Japan new. | eBay
Wheel fairings
Upper Wheel Fairings are designed to give bicycle wind resistance the slip
I could probably make these out of coroplast, if nothing else.
I imagine things like boat-tail bags and helmets also help, and keeping my head forward and down would reduce frontal area.
Old 07-21-2017, 01:55 PM   #50 (permalink)
Cyborg ECU
Those are cool, Ecky. From what I have read wheel covers or deep dish designs need to make an even plan with the outter edge of the tire, if possible, for best effectiveness.
