Old 01-12-2010, 11:07 AM   #11 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
Do you have a scangauge?
This. Among other things, it'll help you see if the fan is working. Mine gets to 206 water temp, then the fan comes on until it's down at 198. If it doesn't cycle the temperature down like that, it may not be working.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 01-12-2010, 02:53 PM   #12 (permalink)
Black Magic - '96 Civic HX
90 day: 46.37 mpg (US)
Thanks for the ideas and advice!
You mean like the one inch coper pipe insulator for the lower? I can probably snag some of that at menards or home depot, right?
Old 01-12-2010, 03:41 PM   #13 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Protege DX
90 day: 42.23 mpg (US)
Your Prizm looks just like my 97 Mazda Protoge. The grills look the same. I used the shrink wrap plastic that you put on windows in your house to cover the entire lower grill block. I have a scan guage and never get over 205 degrees.
It cost me $1.64 at home depot. When it starts to warm up I'll watch the temp and if it ever gets over 210 then I can just rip it off. I'll spend another $1.64 next fall.
Check my fuel log and mod history to see the other things I've done.
I know ford and mazda share platforms but your Prizm and my Mazda are real close.
The Following User Says Thank You to busypaws For This Useful Post:
justjohn (01-12-2010)
Old 01-12-2010, 04:07 PM   #14 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
justjohn -
I have seen two sizes for the pipe insulator. The fatter diameter one will squish tighter into the space, but the thinner diameter one may be more appropriate. It just depends on the size of the gap of your grill. Here are some that I have :
Here is the fatter one installed :
I could probably wedge it in farther, but I wanted you to see it in the picture.
I just did the above so that you can see it. In sunny SoCal I mostly don't use it anymore because I am using my spring-mounted grill block. I do have a short fat piece that I put behind my license plate, but that's all I need right now.
What I *should* be doing is adding grille block insulation at night on the cold drive home, and removing it during the warm sunny drive to work.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
Old 01-12-2010, 04:16 PM   #15 (permalink)
I was thinking the 3M window insulation. I.E. Clear plastic that you attach around a house window frame with double sided tape. Then you use a hair drier to shrink it so there are no wrinkles. Google 3M Window Insulation Kits.
Old 01-12-2010, 11:02 PM   #16 (permalink)
Yeah, interesting idea. No problems with the tape on the car paint then?
Edit:
What about 3M-ing the top and insulation for the bottom to keep it easily adjustable? I heard lexan in the past, but shrinkwrap sounds cheaper and easier.
Jetta TDI Duct Tape Mods Sayyad Aerodynamics 31 09-22-2011 09:46 PM
My turbo-delsol- aero mods pgfpro Aerodynamics 67 11-09-2010 10:14 PM
could we estimate the gains expected from mods modmonster EcoModding Central 9 01-15-2010 08:32 PM
Cd change for irreversible mods Piwoslaw Aerodynamics 3 11-14-2009 04:50 PM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
