Old 04-15-2008, 03:22 PM   #11 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Google bacteria and gasoline and the majority of the hits are about using bacteria to produce hydrocarbons. And here Fitch is trying to kill them. Sounds like Big Oil at work to me.
Old 04-15-2008, 06:05 PM   #12 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
May be a throw back to Bacteria growth in Diesel (Can be a legitimate problem, but usually is not) I don't know
6 speed ALH TDI
Old 05-05-2008, 11:04 PM   #13 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Civic Sedan LX
90 day: 35.68 mpg (US)
Arrow
Yes, I saw the Fitch Fuel Catalyst on TV ... probably a show on the Speed Channel.
Looks like pure BS to me. I don't understand how the fuel can be changed (or the catalyst would be used up in a tankful or two).
My guess is that all it does is filter the gas ... which is what your fuel filter is supposed to be doing.
Fuels that start in a gaseous form should burn more completely as they are pre-atomized. The problem comes with the size of the fuel tank/cell and the (lack of) ease in handling the fuel as it often has to be under significant pressure.
Yes, most cleaner-type products that advertise the ability to improve fuel economy are simply restoring some ability that has been lost due to fouling of the injectors, valves or other parts of the fuel system.
Very few claim enhancements over a clean engine ... but there are a few. Some of these are Marvel Mystery Oil (MMO), Lucas UCL, Schaeffer Soy Neutra 131C and a few others. These claim to increase the lubricity of the fuel which would reduce the parasitic drag of all engine parts that come into contact with fuel ... namely the piston rings.
I have used these and for a month-long run, found that MMO may have worked to increase mileage as much as 5% over 3-4 tankfuls. Have any old 2-cycle oil laying around? Try adding that to your fuel ... so that you end up with a 200-250:1 mix ratio.
Whenever I try these adds, I always give my engine a break after a few tankfuls in case and of this stuff is building up where it doesn't belong. For a quick cleanu-up, I use either Chevron Techron or Red Line Oil SI-1 in modest doses. No need to add more that 2 bottles of these powerful cleaners to your tank per 15,000 miles.
Something else to consider is simply switching to a thinner oil in the motor and trans to reduce hydrodynamic drag. Try a 5 or 0W-20 in the motor and Pennzoil Syncromesh in the manual transmission. Just be aware that these MAY accelerate wear ... though I have not seen proof of this, in cast just the opposite: UOAs (Used Oil Analysis) shows that 0W-20 protects very well ... even in motors calling for 5 and 10W-30.
--- Bror Jace
Fuel Economy related papers tasdrouille General Efficiency Discussion 33 03-06-2012 12:22 PM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
Why SUV fuel economy is so much more important than small car fuel economy... SVOboy General Efficiency Discussion 30 02-23-2009 06:26 PM
DIY decel fuel cutoff; alternator regulation; auto start/stop MetroMPG EcoModding Central 0 11-29-2007 02:04 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
