Old 10-22-2013, 06:47 PM   #1 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Fixing heated seat!?
Hi friends!
My wife's car is a Hymotion Prius. One thing we liked was that when we got it, it already had an aftermarket heated driver's seat.
There's just a little rocker switch on the side that lets you do low/off/high and has a little red light. The light quit working and the seat no longer gets hot, and winter is coming!
I have never worked on a heated seat before! I can assume that the heating circuit itself, the switch, or a fuse could be bad, but I have no idea what or where. Where is the fuse for this thing for example? I have no clue!
Any general advice on working on this!?!?!?
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 10-22-2013, 06:52 PM   #2 (permalink)
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
I would start at the source of power for the heated seat. You should be able to trace the wires from the switch to wherever the installer tapped power from. It could have simply blown a fuse in the cars fusebox, or maybe a wire came loose. If you can measure voltage from the source, inspect the wiring to the switch for damage. If everything appears good to the switch, check for fuses in the switch or inline with the wiring of the seat heater. It's possible the switch is broken. You could jump the switch to bypass it, and see if the seat heats up.
1998 Honda Civic HX - My Project Thread
Old 10-22-2013, 10:31 PM   #3 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
i'm installing heated seats right now; if it's like what i have(low/off/high), there's a relay and a fuse in the circuit, but it could also be how they tapped into the power source.
does your 12v aux(cigarette lighter) work?
are you trying it without the car running, should be attached to a run only line.
Old 12-03-2013, 06:50 PM   #4 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
I finally got a chance to work on this.
We've had one real snowfall so far this winter, so it's been cold enough to encourage me to work on it as soon as I had some time.
I had about and hour and a half available to me this afternoon, and it was above freezing, so I gave it a shot.
To start with, a Gen 2 Prius has four 14mm bolts that hold in the driver's seat. There was plastic covers over the two back bolts, but not the two front ones. Those covers were easy to remove and set out of the way.
The bolts came out pretty easy. Always a blessing. In my experience, on any older vehicle, 3 bolts holding in a seat will come right out, and the last one will not…. ever. If it can, it usually involves cursing and a can of MAP gas.
With the bolts out, I could tilt back the seat to see the wiring under it. There was 3 stock cables going under the seat. I assume the yellow one was for the airbag and the other two are probably a seatbelt sensor and a occupancy sensor. There was one other wiring connector that looked very after-market, with one red and one black wire.
I unplugged all the cables. They all came apart pretty easily. I then took out the seat, so I would have room to work.
I tested the heated seat power connector with my multimeter. There was no power there whether the car was on, off, or on "accessory" mode. The black wire was grounded to the car body under the seat. The red wire ran away to under the carpet, and then beyond that it was covered by interior body panels.
I poked around under the dash until I found a "one of these things is not like the others" red wire going to the small fuse panel near the parking brake. I pulled it down to where I could see and work on it. The red wire tapped into the fuse box in an interesting way so as to replace the fuse AND pull power at the same time.
I followed the red wire back to…… NOTHING! There was a 1/4-inch spade connector with nothing where a wire should have been. Obviously, a bad crimp had been made by the original installer. I pried away the interior body panel directly below and found a 7.5a in-line fuse holder, with a bad bare wire end. The other end of it disappeared going the direction of the drivers seat.
I trimmed the end of that wire, stripped it, and crimped a new 1/4" spade connector. With that in place, and the fancy red wire with the fuses built it plugged back into the fuse box, I tested power under the seat and finally found some; 14.21VDC.
I put the seat back in place and plugged everything in. I then tested the seat heater BEFORE running all the bolts back in. It tested fine. It does indeed have power with the car in the ON or ACCESSORY position, but NOT when the car is OFF.
While the seat was out, I examined it, looking for any loose wires, scorch marks, or worn insulation and didn't see any similar problems.
The whole thing took about an hour, and didn't require any more skills and materials than simply testing for voltage with a multimeter and making one electrical connection crimp.
Whew, it was one of those rare occasions in auto repair where everything went right!
The seat heater works now…… which makes my wife happy….. which makes my life easier!
By using a block heater for the engine, and a seat heater for the driver, I can force the car to EV mode AND not freeze to death. Getting 3000 MPG in a Wisconsin winter is a pretty cool trick.
I'm still limited by the front defroster kicking on the engine. I may have to resort to a 12V Harbor Freight dashboard defroster!
Anyways, so long as my wife is happy, everything is good.
My YouTube Videos
The Following 2 Users Say Thank You to bennelson For This Useful Post:
Cobb (12-14-2013), redpoint5 (12-14-2013)
Old 12-14-2013, 12:06 PM   #5 (permalink)
Glad you got it fixed, nice write-up. Pretty much how I figured it'd be set up, but nice to have a step by step explanation.
heated, prius, seat, winter
